Is it hard to change a 03 rsx type-s clutch? Help please
well it can be a pain. one of the front bolts is a pain to get to. also you have to drop out the cross member first. other than that you have plenty room to work. Any questions hit me up.
the only difficult part is if you are removing the tranny from below, then u will have to drop the subframe, if u have access to air tools and a lift then it will not be hard, other wise it will be more difficult if you dont have ample space with organized tools.
if u decide to remove the subframe you will want to support the engine with something,
02 Civic SI 865
Dec 16, 2006 06:44 AM
