I seriously need some help with my rex, i've tried everything and it wont start?
Old Oct 26, 2004 | 07:04 PM
ewing86's Avatar
Default I seriously need some help with my rex, i've tried everything and it wont start?
I know i have spark and i know its a fuel related problem. When i spray starter fluid into the tb it starts up and runs for a second then stops, i have a fuel pressure gauge on the fuel filter that reads 40 psi, so i kno thats good, its my injectors thats stopping my car from running, their not firing i'm getting no codes, after cranking i dont smell fuel, tried new main relay checked all grounds, tried different resistor box, what happend was car was running fine for like 3 months, i start daily driving it about a week ago, everything is fine, go to a gas stating pump gas takes 3 sets of long cranks finally starts drive around its fine drive home start hearing a scracting noise everytime i turn the wheel to the right pull into the drive way my alt pulley was hitting the shock tower bang that out some more and hasn't started since.
Old Oct 26, 2004 | 07:17 PM
HatchBox's Avatar
Skoobie no more...
Default Re: I seriously need some help with my rex, i've tried everything and it wont start? (ewing86)
What kind of motor? and is it DPFI or MPFI?
Also if it was the injectors it would deffinatly throw a code.
maybe you have a block somehow in the filter to fuel rail?
Old Oct 26, 2004 | 07:19 PM
ewing86's Avatar
Default Re: I seriously need some help with my rex, i've tried everything and it wont start? (HatchBox)
my bad i forgot, 90 dx with a b16a1 pr3 obd-0
Old Oct 26, 2004 | 07:21 PM
HatchBox's Avatar
Skoobie no more...
it might be your fuel pump?
Releive the pressure in the fuel lines, and prime the pump see if it primes back to 40psi
ewing86's Avatar
it does already check my injects are not firing, i'm pretty sure
Old Oct 26, 2004 | 07:25 PM
HatchBox's Avatar
Skoobie no more...
did you try different injectors?
unbolt the fuel rail and see if the injecters are firing.
you can use and OBD0 injectors. so just take them off the original motor, If you have it
Old Oct 26, 2004 | 07:27 PM
ewing86's Avatar
yea i just put injectors from a working car on their and still nothing happened,
Old Oct 26, 2004 | 07:30 PM
HatchBox's Avatar
Skoobie no more...
do you own a voltmeter?
check to see if your getting any current to the injector plugs.
Old Oct 26, 2004 | 07:32 PM
ewing86's Avatar
yes i have a mulitmeter, how much do i look for in the injects, and do i take the plug off and look their, and do i chech when cranking or when the key is turned to on?
Old Oct 26, 2004 | 07:38 PM
HatchBox's Avatar
Skoobie no more...
first just check to see if your getting voltage,
dont quote me on this im pretty sure this is what you do.
unplug the plug, and connect the prongs to the tabs inside the clip.
and check for voltage when the car is cranking.
im not sure how much your looking for
Old Oct 26, 2004 | 07:40 PM
ewing86's Avatar
how many volts does it need to be,
Old Oct 26, 2004 | 07:42 PM
BOSS-REX's Avatar
Is there gas in the tank?
Old Oct 26, 2004 | 07:43 PM
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">
im not sure how much your looking for </TD></TR></TABLE>
ewing86's Avatar
Default Re: I seriously need some help with my rex, i've tried everything and it wont start? (BOSS-REX)
yes
ewing86's Avatar
oh
Old Oct 26, 2004 | 07:44 PM
ewing86's Avatar
are u out of suggestions cause i'm gonna stop for tonight i think
Old Oct 26, 2004 | 07:45 PM
HatchBox's Avatar
Skoobie no more...
yea, just try that volt test.
Old Oct 26, 2004 | 07:47 PM
ewing86's Avatar
ok i will, thanx for your help though, it is appreciated
Old Oct 26, 2004 | 07:53 PM
unite's Avatar
I think in OBD-0 cars the injectors have 4 volts each. Someone correct me if I am wrong.
phat00civic
13
Apr 22, 2012 09:36 PM
oakpwr
Jan 13, 2007 08:43 AM
red92EG
Jan 16, 2006 07:59 PM
DAGS-R
Apr 1, 2005 02:59 PM
one pnt 6 hatch
Oct 23, 2004 11:18 AM
