blurry haze on my headlights
Old Oct 26, 2004 | 06:00 PM
f23accord's Avatar
Default blurry haze on my headlights
Ive got this kinda blurry haze on my headlights on the exterior, anyone know how i may be able to clear this up? at first i thought it was cuz of the hids heat that used to be behind it but ma boy told me he thinks the temp on hids are lower than standard halogens....da hell can be causing it to haze like that?
Old Oct 26, 2004 | 07:09 PM
khunt0012's Avatar
Meat Robot Invisible
Default Re: blurry haze on my headlights (f23accord)
Is it the actual headlight assembly that is "hazing" up? Or is it due to the HID conversion? If it's the headlights, then I have a good way of cleaning them up and making them look brand new again. Just let me know.
Old Oct 26, 2004 | 07:27 PM
rival12's Avatar
Default Re: blurry haze on my headlights (khunt0012)
how do you make them look brand new, if its not the lights?
Old Oct 26, 2004 | 07:35 PM
khunt0012's Avatar
Default Re: blurry haze on my headlights (rival12)
First thing you need is 2000, 2500 and 3000 grit sandpaper. You'll also need Mothers Mag(or Alloy) Wheel Polish.
Step 1: Wet sand (as in wettting the sandpaper) with 2000 grit sandpaper until you get a hazy finish, it'll look better than when you first wet sanded it, but it still wont look great yet. Let the headlights dry.
Step 2: Repeat Step 1, but this time with 2500 grit sandpaper, the hazing should be going down in severity.
Step 3: Again, some process but with 3000 grit sandpaper, hazing should be even less so now.
Step 4: Use mag wheel polish on wet sanded headlights. I personally polished them over the course of 3 days. However, this really isn't necessary. Polish, dry and repeat until you get the desired effect. If it's not working too well go back and resand with 3000 or even 2500 grit and then try to polish again.
I personally got mine to look like bran new, but it took alot of time and effort. With this process it'll prolly take you about 2-3 hours, but the headlights should look way bettr than before.
Old Oct 26, 2004 | 07:52 PM
hawkmgc's Avatar
there is a much faster and easier way to do this.
If someone can find out the product that they use at the airports to polish the planes windows. That is the best stuff in the world to use to clean them up like new. There was a person on Ebay selling this but would not tell the chemical name. And a friend of mine bought some but it came in a non-labeled bottle.
Doubt they are selling it any more as it is an Illegal chemical to be selling on Ebay as it is flamable until it drys.
If you can get a hold of some of this stuff, its the fix to all the headlight fog.
Best of luck
Old Oct 26, 2004 | 08:24 PM
f23accord's Avatar
Default Re: blurry haze on my headlights (hawkmgc)
is there like a plastic polish or somethin i could use, think i heard someone talk bout it before that can make it look pretty good wit a lil elbow grease
Old Oct 26, 2004 | 08:55 PM
hawkmgc's Avatar
but using that polish you have to take them apart to do that. So if you feel safe doing that go ahead.
With the Chem. that the airports use you just put some in, swish it around for acouple of min. then clear out let dry.
No dismant. needed.
Good luck
Old Oct 26, 2004 | 09:01 PM
f23accord's Avatar
But the haze isnt inside of the headlights, its on the outside...so no need to disassemble it (thank God)....and where can i get some of this stuff your talkin bout? would i be able to find it at a autozone or oreillys?
Old Oct 26, 2004 | 11:49 PM
iam7head's Avatar
plastic polish do work, but that stuff is mild and weak compare to the industrial cleaner.
try plastic polish, i think 3m made those also, autozone or marine boat place should have them
Old Oct 27, 2004 | 09:02 AM
1RDROSE's Avatar
Novus Plastic Polish is excellent stuff.
Old Oct 27, 2004 | 09:38 AM
TouringAccord's Avatar
H-T Order of Merit
Here a thread by Spade.
https://honda-tech.com/zerothread?id=938083
He did it to a Mustang and an Integra. Turned out real nice to, big difference.
Old Oct 27, 2004 | 12:09 PM
f23accord's Avatar
Default Re: blurry haze on my headlights (TouringAccord)
Awesome, thanks yo
Old Oct 30, 2004 | 10:45 PM
SuShiBoiiii's Avatar
you should try that product that meguirs makes its works pretty good.
Old Nov 4, 2004 | 07:57 PM
Namikuz's Avatar
Default Re: blurry haze on my headlights (SuShiBoiiii)
00 Steelwool with soap and water, then break out the TOOTH PASTE and a soft cloth. Polish them up! YES I AM SERIOUS!!!!!!! It works excelent and it's CHEAP TO DO!!!
Old Nov 4, 2004 | 08:04 PM
Beach Accord's Avatar
sounds like sun damage.... i always thought the only cure for it was to buy new lights....
Old Nov 5, 2004 | 01:38 PM
f23accord's Avatar
Default Re: (Beach Accord)
I just used some plastic polish from autozone yesterday....amen, that **** worked great, i can actually see my headlights bling now, its some woo sah **** now
Old Nov 5, 2004 | 06:45 PM
calean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khunt0012 &raquo;</TD></TR><TR><TD CLASS="quote">First thing you need is 2000, 2500 and 3000 grit sandpaper. You'll also need Mothers Mag(or Alloy) Wheel Polish.
I personally got mine to look like bran new, but it took alot of time and effort. With this process it'll prolly take you about 2-3 hours, but the headlights should look way bettr than before.</TD></TR></TABLE>
Thanks for this man. I've been wondering how to clean that stuff off.....
Old Jul 25, 2005 | 02:39 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: blurry haze on my headlights (calean)
WHERE DO U GET 3K GRIT? I ONLY SEE 2K
Pmartos24
Mar 16, 2015 06:04 PM
Crono139
Detailing
90
Jan 1, 2012 07:13 PM
donger
Lighting
33
Aug 20, 2010 09:37 AM
donger
Aug 19, 2008 07:25 PM
hialeahzbg
Feb 21, 2006 07:50 PM
