B16a Change Over
http://hmotorsonline.com/shop/...00291 JDM
-on this link i found exactly what i need. It has everything i need for a b16 swap. but at the bottom it says: "We can supply you with the hasport mount kit for $350 and the hasport linkage for $50. Prices only valid with purchase of a complete changeover. We can also supply you with 90-93 Integra steering knuckles and hubs for $50 if you need them. Also availabe is the Hasport Aluminum A/C bracket for $160 and the Hasport wiring sub-harness for EF civics that are either HF or Si models (not DX or STD) for $60." Do i need any of these things. I have a 1991 CRX Si. Will SIR axles fit into a CRX without changing the hubs?
you dont need the steering knuckles or any of that crap only dx an std models need them the only thing youll need are the motor mounts unless u make some mods to the ones that come with your swap that also depends on the tranny u go with if u go with the cable youll need the ones set for that and the hydro tranny will also need mounts with the adapter plate go with hasport on either of those,for the axles im pretty sure they would fit but id look into that i just know this becasue i have an std civic and i needed all the parts u dont cause you have an si which is already mpfi and mine was an dpfi basically meaning i have a crap model compared to your but any ways good luck
civicdust
May 2, 2005 09:11 PM
88crx Osaka
May 29, 2003 09:30 PM
