Distributor wiring Q's.
Old Oct 26, 2004 | 04:45 PM
thumbtack's Avatar
Default Distributor wiring Q's.
Ok I am still getting codes for Crank Position Sensor, Cylinder Position Sensor, and Top Dead Center... I started with a 91 dx that now has a OBD1 D16Z6 with P28 ECU. I used locash racing conversion harness. The distributor is a Distributor King model. I purchased it when I did the swap.
Does anyone know the correct wiring from the distributor to the ecu? Color of the wire from the distributor, to the Pin # on the ecu?
The car runs perfect, then it starts stuttering and no matter what, it always throws the codes. I have tried swapping wires around, and it just wont even start, so I think I must have a bad wire, one of my injector wires was this way and i just ran it from the injector to the ecu, and it worked fine. It is really bad when I step on the gas and it makes a sound like it is cutting the spark to the cylinders or something.
riftonthemind057
Mar 27, 2008 01:08 PM
thumbtack
Dec 8, 2004 05:11 PM
HybriDNA
Feb 13, 2003 03:56 AM
serious
Jan 6, 2003 06:12 AM
