Service Check connector to jump when checking Ignition Timing
Old Oct 26, 2004 | 04:29 PM
94CoupeEJ1's Avatar
Default Service Check connector to jump when checking Ignition Timing
I went to check my timing last Sat and couldn't find this wire. Helms says it's behind the right kick panel and shows it by the ECM. I found the ECM but I couldn't find the wire. Anybody know where I'm supposed to be able to find it. 94 EX Coupe.
Old Oct 26, 2004 | 05:00 PM
The Internet Tough Guy's Avatar
Default Re: Service Check connector to jump when checking Ignition Timing (94CoupeEJ1)
its right down there. look a little harder, you'll find it.
Old Oct 26, 2004 | 05:35 PM
94CoupeEJ1's Avatar
Default Re: Service Check connector to jump when checking Ignition Timing (jwn7)
Went and stood on my head looking up behind the glove box. There is a green jacketed wire with a connector not plugged into anything. Is this what I am looking for? It is close to the ECM. It is not plugged into anything. Is the wire I'm looking for already plugged together and need to be unplugged? Thanks for the help.
I checked again and the connector on my green wire is exactly the same kind of connector as your pic except it is light blue. I betting it's the wire I'm looking for. Helms says black and brown. Thanks
Old Oct 26, 2004 | 05:50 PM
hayabusa160's Avatar
yep the green jacket cover is covering it thats the one.
some cars its blue my freinds 96 hatch was
Old Oct 26, 2004 | 05:55 PM
94CoupeEJ1's Avatar
Default Re: Service Check connector to jump when checking Ignition Timing (hayabusa160)
Thanks for the help
Old Oct 26, 2004 | 06:03 PM
snowman0520's Avatar
what are u supose to do with that wire when checking timing?
Old Oct 26, 2004 | 06:23 PM
Default Re: Service Check connector to jump when checking Ignition Timing (snowman0520)
you stick a paper clip in the connector.
Old Oct 26, 2004 | 07:02 PM
thrty8street's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 &raquo;</TD></TR><TR><TD CLASS="quote">you stick a paper clip in the connector.</TD></TR></TABLE>
and then what? how does that check timing?
Old Oct 26, 2004 | 07:07 PM
handa's Avatar
Default Re: Service Check connector to jump when checking Ignition Timing (thrty8street)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street &raquo;</TD></TR><TR><TD CLASS="quote">
and then what? how does that check timing?</TD></TR></TABLE>
It doesn't bro. Stick the paper clip in the connector. Then use timing gun to check ignition timing.
Old Oct 26, 2004 | 07:21 PM
flat-blk-HB's Avatar
Default Re: Service Check connector to jump when checking Ignition Timing (handa)
and what exactly does this do?
Old Oct 26, 2004 | 07:23 PM
FIGARILA's Avatar
Default Re: Service Check connector to jump when checking Ignition Timing (flat-blk-HB)
mine was crammed up in there... very well hidden.
Old Oct 26, 2004 | 07:43 PM
Default Re: Service Check connector to jump when checking Ignition Timing (FIGARILA)
it puts the ecu into service mode. you need to do this when adjusting the ignition timing, because with the ecu running in normal mode, it will try to correct your timing.
you noobs need to fork over the $70, get a helms manual, and read it
Old Jun 6, 2005 | 10:26 AM
hondainspired's Avatar
Default Re: Service Check connector to jump when checking Ignition Timing (The Internet Tough Guy)
god i love searching ... this thread helped me a **** load... greatly appreciated...
Old Jul 19, 2009 | 08:41 PM
SinsEvil666's Avatar
Yup, just helped my *** alot too
Old Jan 1, 2013 | 01:59 AM
Kraiye's Avatar
and me too... 8 years later. lol
google + honda forums = win
Donkey85
13
Aug 3, 2011 12:08 PM
PushnFords
Nov 23, 2007 09:34 PM
themorphious
Jun 6, 2006 02:44 PM
Battle Mike
Nov 18, 2003 05:09 PM
lahight
Mar 6, 2003 01:02 AM
