z6 intake manifold question
im doing z6 swap into my 90 crx si, and im having a little trouble with the intake manifold.
on the z6 IM, theres a vacuum plug (not sure what its called) on the bottom back drivers side of the IM (with the IM installed). on the z6, what hose or vac line does this go to? also, does the z6 have a FITV and where is it located?
last question, are b-series and d-series map sensors interchangeable?
thanks
thanks
if you give me a quick picture of which plug your talking about, I can tell you. I can't visualize picture sin my head very well. I know one goes to your map, did you get that one?
The small vacuum line on the bottom, back, drivers side is the cruise control vacuum line.
No fast idle valve on the Z6 manifold, if it needed one, it was on the throttle body.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Br1anPham »</TD></TR><TR><TD CLASS="quote">if you give me a quick picture of which plug your talking about, I can tell you. I can't visualize picture sin my head very well. I know one goes to your map, did you get that one?</TD></TR></TABLE>
sorry ill try to snap a pic...but yea its the one on the bottom of the intake manifold near the master cylinder.
umm i didnt get the one that goes to my map, where is the plug for that?
thanks
thanks
EJAYATE
12
Feb 8, 2008 11:01 AM
Manny86
Oct 29, 2006 07:32 PM
