WTF 92 CX, proportion valve help, rear disc conversion searched.
i orderd an integra prop valve and recieved it in the mail. it only has 4 ports on it for break lines. well my CX prop valve has 6, well it looks like there is 2 propvalves bolted together, and they are shaped like a triangle. each has 3 ports on it so im all confused. i have 2 lines that come off the MC, then 1 line goes to one prop valve and the other goes to the other, then one conrols one side of the cars breaks and the other controls the other side. what do i do???
Landon
Landon
I believe the integra proportioning valves that only have 4 holes are for ABS equiped integras. I have the integra (non ABS) 4040 valve on my car and it looks exactly like my 94 CX's with a different mounting bracket.
BTW: because of the integras mounting bracket, the valve was very hard to get the lines bolted into. It's not recessed like the civics, and brake hard lines have to point perfectly straight to get threaded on... Since you will need a new prop. valve anyways, you should try to get the civic's instead of the integras. Hopefully you can return the one you have.
Ron454321
16
Apr 25, 2011 03:05 PM
boosted_dc2
Oct 26, 2004 06:02 PM
midnightdarknes5
May 20, 2004 11:59 PM
