Headlight relay in 95 accord?
Old Oct 26, 2004 | 10:53 AM
technine's Avatar
Default Headlight relay in 95 accord?
My bro is still having headlight problems in his 95 accord ex. Driver light is out and has a very dull glow when on (almost can't see it at all) and passenger side is fine. When he switches to high beam, driver side doesn't work at all and passenger side works like it should.
Someone told him it could be the relay for the headlights. Is there a relay for the headlights? Where is it located? If I could find the relay, I could replace it for him, but I am very unfimiliar with accords and especially electrical component locations. Anyone know where it is or if it even has one? TIA
Old Oct 26, 2004 | 11:10 AM
Old Skool's Avatar
Default Re: Headlight relay in 95 accord? (technine)
im kinda having the same problem...i got JDM depos and i've been told its a bad chassis ground.
Old Oct 26, 2004 | 11:38 AM
technine's Avatar
Default Re: Headlight relay in 95 accord? (Old Skool)
I tried just grounding it off to a good ground, but straight from the headlight itself with no success. I'm thinking of ghetto rigging the drivers side with a relay and tapping into the passenger for an on signal to turn it on. This is the last ditch effort if I can't find the relay or if there is no relay at all.
Old Oct 26, 2004 | 11:43 AM
Old Skool's Avatar
there is a relay in the fuse box under the hood, other wise it could just be a bad wire in the harness for the headlights...i sitll have to do research on mine to finds out exactly where it is...i hate wiring.
Old Oct 26, 2004 | 03:16 PM
technine's Avatar
Thanks, I'll check that.
Old Oct 27, 2004 | 12:22 PM
technine's Avatar
Update:
Turns out it was the FUSE!!!! We were looking at the underhood fuse box diagram the wrong way!! Damn, my bro drove like this for 6 months, hahahahahaha!!
Old Oct 29, 2004 | 01:59 PM
Old Skool's Avatar
haha, mine was the fuse too! i've been puting it off and it wasa 5 sec. fix.
77Malito
Lighting
Nov 8, 2017 04:28 AM
eazy97
Jan 23, 2009 12:59 PM
Hando
Oct 10, 2007 02:27 PM
