Final non-VTEC track results
Ran on the shitty 205/40-16 Yokohama AVIDs (360 wear rating) at first...which werent too bad. The best run on those tires was:
60': 2.132
330': 5.895
1/8: 8.937 @ 80.615
1/4: 13.836 @ 100.477
I was real surprised these tires could manage a 2.1 60 ft!
Then I did a few runs on some 20x8x14 slicks! The first two runs blew *** cause there was 18 PSI in the tires...so on the 3rd run I lowered it to 14 PSI (probably should have gone 10-11). My 60 foot SUCKS for slicks!
60': 1.972
330': 5.619
1/8: 8.671 @ 80.887
1/4: 13.566 @ 100.248
Not too bad I though. Before the rebuild, my best on street tires was 14.0 @ 99.0 with a 2.20 60' and a 13.77 @ 98.4 MPH with a 1.90 60'. So my time dropped 2/10th and I had a worse 60 foot!
60': 2.132
330': 5.895
1/8: 8.937 @ 80.615
60': 1.972
330': 5.619
1/8: 8.671 @ 80.887
12.5-13 psi is the limit, else you'll start spinning the slicks on the rims.
Once you do it once, it will get easier to slip them on the rim next time.
Put a mark on slick marking where the valve stem is. hat way you can monitor slippage.
I would suggest 22x8x14 slicks. Let the torque PULL!
Yep...I think Ill buy a set of 22x8x13s!
I seriously believe with a 1.8X 60'..which is what I should run on slicks...I would have ran at least a 13.3
hey HX guy
I have some Bogart pro 4's. I dont think you want to use the slicks that are on them. BUt 350.00 for 13" bogarts with 25" slicks... CAme off of Kenny Trans car here in TX... Bought it from a guy who bought one of there cars.. HIt me an email if interested.
synergy004@aol.com
synergy004@aol.com
Wow...those are HUGE! Which isnt bad...my friend ran a 13.1 on 24.5" slicks. But they wont fit under my fenders
Ill have to stick to 22x8x13
01PYTypeR#1140
May 24, 2002 01:30 PM
