shifter falls out of car
Old Oct 26, 2004 | 08:48 AM
messeduprex's Avatar
Default shifter falls out of car
i have a 91 crx with a zc and si trans my shifter fell out onto the ground while driving i replaced the shifter bushings with energy suspenions worked like a charm for about two weeks and it did it again i ripped the back bushing in half does anyone know what could be causing this to happen i'm thinking about switching to the b&m meatl bushings but would like to fix this problem before hand and just for added in put my shifter moves about an inch when i accelerate
Old Oct 26, 2004 | 08:56 AM
Turbo E's Avatar
Default Re: shifter falls out of car (messeduprex)
if your shifter moves that much, i'd say your motor mounts are shot.
did you lube the bushing before installing it? i dont see how you can rip a urethane bushing tho.
besides therse a metal plate that goes under it so even if your shifter bushing tor out completely that plate shoulda held the shifter up.
Old Oct 26, 2004 | 09:04 AM
Default Re: shifter falls out of car (Turbo E 604)
the first time the metal rod the slides inot the bushing ripped out of the bushing an thats exactly what happend this time but the bushing i copleatly torn on the hump of the bushing but the bushing and the metal peice that holds it on are still where they should be
Old Oct 26, 2004 | 10:20 AM
deftones0817's Avatar
do you have one of the shiftlinkage parts upside down or the shift upside down? Its just weird to hear that...
DEF
Old Oct 26, 2004 | 01:55 PM
Turbo E's Avatar
a pic would help a lot.
darnizzle8805
Jun 20, 2014 06:04 PM
The_Honda_Guy
16
Nov 28, 2009 06:09 PM
eluder33
Nov 20, 2004 03:05 PM
slash00R
Nov 1, 2004 07:23 PM
