First Time - doing front and rear brakes on a 98 Accord coupe V6...Any how-to tips?
Old Oct 26, 2004 | 07:18 AM
andrew n's Avatar
Default First Time - doing front and rear brakes on a 98 Accord coupe V6...Any how-to tips?
I need to replace front and rear brakes on my 98 Coupe V6. I plan on using Brembo blanks and Hawk HPS pads. I have never done brakes on an Accord so I was wondering if I will run into any commom problems and/or if anyone has any tips, website how-to, etc....
Thanks
Old Oct 26, 2004 | 07:43 AM
truesleeper's Avatar
Default Re: First Time - doing front and rear brakes on a 98 Accord coupe V6...Any how-to tips? (andrew n)
Im almost positive that on the later model accords the front hub assemply has to be pressed back on due to the design of the bearing/hubassembly, i had to take my 97 accord to a machine shop to have the hubassemply pressed back on. I could be wrong tho, maybe they changed it but i would look into it befor starting, maybe get a maintenence manual for your car they are a big help. good luck
Old Oct 26, 2004 | 12:08 PM
andrew n's Avatar
Default Re: First Time - doing front and rear brakes on a 98 Accord coupe V6...Any how-to tips? (truesleeper
Anyone else....is this true about thr rotors?
Old Oct 26, 2004 | 12:48 PM
JimBlake's Avatar
I believe '97 was the last year for those pressed-on rotors. The rotors on our '98 come off the normal way...
Rear brake calipers have the handbrake auto-adjust mechanism. You have to twist the pistons clockwise, to push them in to make room for the new pads.
Old Oct 26, 2004 | 01:03 PM
sj993's Avatar
Yeah, I think the 97's were the last year for pressed on rotors as well. That is also for the front only. The rear's came off like normal.
BLUEWOLF1027
Apr 13, 2014 03:12 AM
Lissav
Dec 13, 2008 07:27 AM
Repodevil
Apr 27, 2006 02:52 PM
Elvis1977
Dec 31, 2005 06:03 AM
dynamo
Oct 1, 2004 01:48 PM
