Question?(Camber kit)
Old Dec 19, 2001 | 09:19 PM
DarthLuder's Avatar
New User
Default Question?(Camber kit)
Need some help I'm getting H&R sport springs 1.5 drop front , 1.3 drop rear with some koni yellows is a Camber kit necessary? If so what brand should I get (heard ingalls suck)?
[Modified by O0oToOKo0Oo0OR555, 6:19 AM 12/20/2001]
Old Dec 19, 2001 | 09:20 PM
AllMotorITR's Avatar
New User
Default Re: Question?(Camber kit) (O0oToOKo0Oo0OR555)
A) I heard that ingalls is good.
B) No you don't I have that same setup with same drop.. It is fine.
Old Dec 19, 2001 | 09:23 PM
DarthLuder's Avatar
New User
Default Re: Question?(Camber kit) (1 FAST R)
Thanks for the help. How is the handling compared to stock 1 FAST R?
Old Dec 19, 2001 | 11:33 PM
austrian type-R's Avatar
Mine is lowerd with springs about 1.5 inch and all I can say is, GET A CAMBER KIT.
NOW: better handling, less tire wear out. It is worth!
You need only a kit for the front. For the rear you can do the washer trick, but you need longer bolts! For safity instal maximal 4 washers on each side on the 2 bolts.
I had about -2.5 to -2 degree negative camber and now I´ve about -1 deg.
ezol
Jan 6, 2007 03:30 PM
Doom325
Jan 30, 2005 09:00 AM
EriK20
Aug 21, 2003 05:47 PM
osbornsm
Aug 15, 2002 09:19 AM
spangler
Apr 10, 2002 09:52 AM
