distribtor help ???? please help??
https://honda-tech.com/zerothread?id=1034512
i posted one but i get no help again my friend is buying a integra for $600 and he was checking out the car by turning it on and it was fine till he was checking a little to much and he took off the last to the right spark plug wire and the car turned off and never came back on again.... the car has new spark plugs and wires... i checked for sparks in every single one and notting ...so im guessing is a ignition coil right ? and i need the whole distributor ?? im not sure wich one it can be.... i went alot and got a coil for $50 but does not fit cause its from a 92 and the car is a 91 ...someone please hlp
My guesss would be that your coil burned out..... get a new one and see if it'll work (you can always turn it back in). But do not forget to chek the fuses
DiggyDave1984
Feb 8, 2009 07:20 PM
egluism33
May 25, 2008 06:17 PM
s2kkk
20
Apr 15, 2004 11:12 AM
