FS: Parting Out B-Series EK and Audio Gear
Old Oct 25, 2004 | 07:51 PM
Frog's Avatar
Default FS: Parting Out B-Series EK and Audio Gear
A friend looking at parting out his EK. Everything in good working condition, very miticulous about his build from day one. I want to buy the shell should he be able to sell this stuff on it's own. So buy his stuff!!!!!!!!!!!!!!!!!!!!!!!!!! He's not looking for trades unless specified.
His list:
Not including shipping, prices in USD Located in Vancouver, BC (North of Seattle, WA)
Everything out of a 97 Civic
LS VTEC engine (Longblock) -approx 25,000 Mi
C/W Crower 63402 cams/ Skunk 2 cam gears, Crower dual valve springs, titanium retainers with new honda valve keepers.
Endyn 12.5:1 high compression forged pistons (81.5mm bore dia), with Eagle h-beam forged rods, GSR main cap girdle/oil pick up/pan, Clutchmasters (8lb) billet aluminum flywheel/Stage 3 kevlar clutch set. Spoon engine oil and tranny drain plugs. a bunch of new sensors. LSVTEC Oil lines ect..
Engine was built using all new Honda OEM bearing, seals, gaskets, washers
Head, has been ported/polished, crank micropolished and entire rotating assembly balanced, block and head cleaned and decked, cylinders bored and honed, valve seats and valves received a performance grind, many of the sensors have been replaced
All machine work was performed at High performance engines in burnaby.
I'm sure I'm forgeting a bunch of things. Countless hours went into dreaming up this engine let alone assembling it.
Engine produced 183 whp and 135 lbs/ft torque on a dynojet before hondata tuning.
You get everything from the valve cover to the oil pan for
3500.00
JDM GSR Tranny (4.4 final drive) with OEM helical LSD -
950.00 - no grinds at all - smooth as butter.
Set of B16a axles all three - Driver side/passenger side + intermediate shaft (to fit ek hatch) - 210.00 for all.
Shift linkage/rod + short shifter - 105.00 + your stock one.
Custom aluminum oil catch can with PCV valve and drain fitting, filled with filter media (bathroom drain plug chain) - 83.00
JDM Integra Type R Intake manifold with EACV, IAT sensor, throttle bore 65mm, and entire manifold polished - 210.00
Integra ls Throttle body (60mm) with MAP sensor and TPS sensor - 125.00
Red AEM billet aluminum fuel rail - 100.00
96 Prelude 290cc fuel injectors high impedance - 125.00
DC Sport JDM Type r Header with 2.5" merge collector- 125.00
P28 socketed ECU - 210.00
Hondata S200 - 250.00
OBD2a-1 Wire harness adapter (FROG ENGINE CONTROLS) - 125.00
B&M FPR - 25.00
NGK Powercore (R90) JDM Ignition wires - 105.00
Jacobs electronics ICEPAK ignition kit with coil and wire- 170.00
Cold air intake piping/clamps, K&N Filter - 84.00
Will sell everything listed above here for 5900.00
Stereo:
Deck - Sony CDX C910 - top of the line deck - 170.00 + Stock radio
XDP-210 - Digital EQ - 125.00
AVI 5.25" component speakers up front - 83.00
TSD-132 - 5.25" Pioneer German made Coax speakers - 63.00
Alpine - MRV-F400 - 4 channel amp - 170.00
Rockford Power 55.2 amp - 125.00
2 X 10" - JL 10W1 subs in sealed box - 125.00
Sony 6 disc (MP3) changer - 170.00
Not mention distribution blocks and all the wiring. - 84.00
Entire setup for 1000.00
Suspension:
Tein HR Dampers - Height adjustment only (10kg/mm Front / 8kg/mm Rear)-415.00
Old Oct 26, 2004 | 08:32 AM
Frog's Avatar
Default Re: FS: Parting Out B-Series EK and Audio Gear (Frog)
Old Oct 26, 2004 | 06:32 PM
Frog's Avatar
Old Oct 27, 2004 | 04:29 PM
Jaker's Avatar
Bump for my buddy Ryan.
Old Oct 28, 2004 | 11:08 AM
Jaker's Avatar
Default Re: FS: Parting Out B-Series EK and Audio Gear (Jaker)
Up, up amd away.
Old Nov 1, 2004 | 06:40 AM
Frog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">slowsleeper (8:32 PM 10/31/2004): hey i'm interested in that jdm dc header for 125.00. do you have any ppics? let me know asap. thanks</TD></TR></TABLE>
ryan.... send them to me and I'll host them.
P
Old Nov 6, 2004 | 06:12 PM
rhecht's Avatar
Parts are all still on the car unless specified.
If you guys want to check out some pictures.
I have a couple of pages set up so you can view some pictures.
Just hit the following links.
http://members.cardomain.com/rhecht
or
http://publish.shaw.ca/rhecht/
Tyounin608
Jul 11, 2014 07:55 PM
SP GARAGE
Aug 22, 2009 06:59 AM
DOHCIVIC
Aug 8, 2009 02:18 AM
LowNismo17
Southeast (Sales)
18
May 5, 2009 11:28 AM
Ekfoe
Jan 30, 2005 06:47 AM
