90 Integra LS moonroof stuck...help
Old Oct 25, 2004 | 07:29 PM
crx8739's Avatar
Default 90 Integra LS moonroof stuck...help
Ok so I was dumb and tried to open the moonroof on an Integra i recently bought. It opened maybe an inch or two and stopped. I cant get it to close now. I tried pushing the close button and trying to push the glass forward but no luck, and hope to get it closed before it rains, anyone know what I can do that may get it to close, or a quick fix?
Old Oct 25, 2004 | 07:35 PM
HGZ's Avatar
HGZ
Default Re: 90 Integra LS moonroof stuck...help (crx8739)
i remember i did the same thing when i just bought a '90 civic si HB..
i opened the moonroof and it stopped half-way!!! i had no idea what the hell was going on.. turned out that the switch was going bad or something cuz when i moved around and jiggled the wires directly behind the switch, it would start working again!
perhaps your moonroof switch is doing the same thing??
Old Oct 25, 2004 | 08:03 PM
b16a2delsol's Avatar
Dude look in your owners manual and you will see a diagram of how to do i..... Pg48....but im assuming you dont have one so here.
The sunroof can me closed manually, if the control switch will not close it..
1.Remove the round plug near the rear center of the headliner.
2. insert the sunroof wrench (from tool kit) into the socket.
3. Turn the wrench untill sunroof seats in the closed position.
4 replace the plug
i hope that helps
Old Oct 25, 2004 | 08:11 PM
HGZ's Avatar
HGZ
Default Re: 90 Integra LS moonroof stuck...help (sn2bstteg)
haHa is THAT what that plug is for?? i always wondered..
Old Oct 25, 2004 | 11:53 PM
silenttones's Avatar
Default Re: 90 Integra LS moonroof stuck...help (hgz)
thats why i hate sunroofs, but i got mine working cuz it had a bad connection...i figured it was a bad motor, but i can hear it working so then i popped off the button thats on ur dash, and theres this metal connector thing, mine was just hella dirty and corroded, so i cleaned it, and it started working again...if this doesnt help, try sn2bstteg said.
Old Oct 29, 2004 | 07:09 PM
TurboTeG4's Avatar
Default Re: 90 Integra LS moonroof stuck...help (silenttones)
You think if it moves just a little and can hear the motor going it could be the switch on a 94 teggy? Wheres the plug for the 94s to manual open it?
hellorichard
Jul 1, 2017 03:26 PM
livingcb919
Jun 12, 2014 10:28 PM
Dr.Fixit
Sep 20, 2013 04:42 PM
SamN
Apr 26, 2007 04:45 PM
KyleVA
Jan 23, 2007 06:33 AM
