JDM ITR headers question ???
Old Oct 25, 2004 | 06:52 PM
G-bonic's Avatar
Hijacked
Default JDM ITR headers question ???
Hey guys i got a new toy the jdm itr header just came today, my question is would it bolt rite on to my stock 96 LS motor ? do i have to change my piping to 2.5 too or wut ?? lemme know guys.. Thanks in advance...would i pass the smog too ??
Modified by Stock_LS at 8:31 PM 10/25/2004
Old Oct 25, 2004 | 07:00 PM
dFreezy's Avatar
Default Re: JDM ITR headers question ??? (Stock_LS)
you will need either: a full 2.5" cat (which can bolt up to 2.36" and up catback) OR a tapered cat that has a 2.5" inlet and 2.25" outlet (which can bolt up to 2.25" catbacks, obviously).
Old Oct 25, 2004 | 07:51 PM
Kellindal's Avatar
Default Re: JDM ITR headers question ??? (dFreezy)
Also, I think you will pass SMOG, but I think that the 2.5" collector isn't street legal... However, if I remember, the DC sports JDM style header is street legal. Could be wrong about all that, but that's what I seem to remember around the time of the DC one coming out.
Old Oct 25, 2004 | 08:58 PM
purplegsr's Avatar
Default Re: JDM ITR headers question ??? (Kellindal)
The DC JDM ITR is not CARB exempt, only the USDM ones have the CARB stamp. So, the JDM one will not pass a visual inspection if they are looking for CARB stickers/stamps, but it should pass the sniffer as long as you have a functioning cat. The JDM from the top looks just like a USDM header, so maybe you can pry a stamp off of someone's old DC header.
And yes, everyone is right, you need a cat with a 2.5" flange to mate with the 2.5" collector.
Old Oct 25, 2004 | 09:23 PM
dFreezy's Avatar
Default Re: JDM ITR headers question ??? (purplegsr (Exospeed))
also, some people put on the jdm heatcovers to pass visual inspection. they look just like the stock ones
Old Oct 25, 2004 | 09:34 PM
purplegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">also, some people put on the jdm heatcovers to pass visual inspection. they look just like the stock ones </TD></TR></TABLE>
that works too, although you can't use the stock heat shield, it won't fit, you need either a OEM JDM one, or one like it.
Old Oct 26, 2004 | 08:31 AM
G-bonic's Avatar
Hijacked
where can i get those jdm itr headers heatshield and the cat converter ?? any know where ??
Old Oct 26, 2004 | 10:03 AM
purplegsr's Avatar
The JDM heatshield may be a little tougher to track down, but I bet you could call jdmshit.com, hmotorsonline, or anywhere else that would sell OEM JDM motors - they may have an extra one around, or know where to get them. I saw on some other forums that CustomAuto in Canada sometimes has the JDM b16a heatshields, so they may have others as well (email is pbaumbick@customauto.ca).
As for the cat, just have SMSP or kteller8 make one for you. They will use a carsound or other universal high-flo cat and fit on some flanges based on your needs (2.5 --&gt; 2.36 tapered, etc) and add a bung for an o2 if you need it. You could also buy a carsound or other cat online, take it to your local muffler shop, and tell them to weld a nice flange for you.
Old Oct 26, 2004 | 10:09 AM
dFreezy's Avatar
jhpusa.com also has the upper heatshield here
Old Oct 26, 2004 | 03:51 PM
G-bonic's Avatar
Hijacked
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy &raquo;</TD></TR><TR><TD CLASS="quote">jhpusa.com also has the upper heatshield here
ill try this out.. passwordjdm selling cat back for $109 and for heat shield $70 and im like 10 mins away from there so i think im getting it from there hopefully.... if i dont see any cheaper ones...
Old Oct 27, 2004 | 10:49 PM
dt4life's Avatar
Hey I had the same question earlier. I was told to go to http://www.kteller.com for the cat and to my suprise it was a great site. They have a cat that has a 2.5" opening to a 2.25" outlet. Also, I'd go to icbmotorsport.com for your heatshield. I believe it is $53. Plus their stuff is in stock 99% of the time
Old Nov 3, 2004 | 02:35 PM
G-bonic's Avatar
Hijacked
Default Re: JDM ITR headers question ??? (wannaTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannaTypeR &raquo;</TD></TR><TR><TD CLASS="quote">Hey I had the same question earlier. I was told to go to http://www.kteller.com for the cat and to my suprise it was a great site. They have a cat that has a 2.5" opening to a 2.25" outlet. Also, I'd go to icbmotorsport.com for your heatshield. I believe it is $53. Plus their stuff is in stock 99% of the time</TD></TR></TABLE>
thanks this is really helpfull and im about 20mins away from them ready to pick it up....
Old Nov 3, 2004 | 02:40 PM
riceball777's Avatar
you will also need a p72 oil pan which is a gsr or itr oil pan
i am 100% sure you will need a p72 oil pan the header will hit the b16 /ls oil pan and will not sit flush with the head
Old Nov 3, 2004 | 03:23 PM
G-bonic's Avatar
Hijacked
Default Re: JDM ITR headers question ??? (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">you will also need a p72 oil pan which is a gsr or itr oil pan
i am 100% sure you will need a p72 oil pan the header will hit the b16 /ls oil pan and will not sit flush with the head </TD></TR></TABLE>
r u serious ? damn just changing my header into jdm itr one will need a lot of ****... will p72 oil pan fit bolt right onto my stock ls block ??
Old Nov 3, 2004 | 06:22 PM
dt4life's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stock_LS &raquo;</TD></TR><TR><TD CLASS="quote">
thanks this is really helpfull and im about 20mins away from them ready to pick it up.... </TD></TR></TABLE>
Hey no problem, I hope it helps you
Old Nov 3, 2004 | 09:29 PM
r u serious ? damn just changing my header into jdm itr one will need a lot of ****... will p72 oil pan fit bolt right onto my stock ls block ??</TD></TR></TABLE>
yes the oil pan will bolt right up
and trust me like i said i'm 100% sure that you will need a gsr /itr p72 oil pan
Old Nov 3, 2004 | 10:18 PM
LSvtechatch97's Avatar
i have a JDM GSR header on my LS and i didnt have to mess with my oil pan. it just hangs up really high and close to the oil pan. how are you 100% sure, have yo done this same thing in the past? if so then i guess your right but i dont think he needs to.
Old Nov 4, 2004 | 12:46 AM
fuzzie's Avatar
Default Re: JDM ITR headers question ??? (FUKuPAYme)
ee-gsr
Jun 22, 2013 12:08 PM
G-bonic
Dec 10, 2004 10:11 AM
trustbuddy
Jan 3, 2003 10:17 AM
QCKGSR
Nov 22, 2002 11:09 AM
DJHan
Feb 12, 2002 10:49 AM
