Dyno in 3rd or 4th?
the shop I went to did mine in 4th.... no wonder I was so bummed on the results. They said that it's the gear closest to 1:1 ratio and that was why. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrpwr2004 »</TD></TR><TR><TD CLASS="quote">im pretty sure 4th gear isnt close to 1:1 i think 4th gear is 1:1 because it is a direct drive!</TD></TR></TABLE>
it is the closest to 1:1 than the other gears, on b18b's its 0.966 and b18c's its 1.034. i still love 3rd gear 'vtack' the best though
How do you figure? GSR 3rd is 1.360 and 4th is 1.034. That's a difference in torque multiplication of approximately 24%, all else equal. So to make the math easy, if torque in 3rd is 100 lb/ft, then in 4th it would be 76 lb/ft. Plug it into the HP formula: HP=(Torque x RPM)/5252, then at 8000rpm, you would get 152.32 hp in 3rd and 115.77 in 4th, which reflects the 24% difference. That's a big difference! How's my math?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kchungb17a »</TD></TR><TR><TD CLASS="quote">How do you figure? GSR 3rd is 1.360 and 4th is 1.034. That's a difference in torque multiplication of approximately 24%, all else equal. So to make the math easy, if torque in 3rd is 100 lb/ft, then in 4th it would be 76 lb/ft. Plug it into the HP formula: HP=(Torque x RPM)/5252, then at 8000rpm, you would get 152.32 hp in 3rd and 115.77 in 4th, which reflects the 24% difference. That's a big difference! How's my math?</TD></TR></TABLE>
damn, this ***** sounds likes he knows his ****!! impressive
It could. If you wanna compare apples to apples, and everyone else's teg was done in 3rd. Apparently the legit way is to do it in 4th, so I don't know why anyone would have it done in 3rd to begin with. So by my calculations, your car should lay down approx. 218 in 3rd. But knowing that isn't gonna make it go any faster, right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. »</TD></TR><TR><TD CLASS="quote">i gota dyno vid of a 852awhp wrx doing it in 4th.. </TD></TR></TABLE>
damn! the coolest AWD one i have is an R33 almost coming off of the dyno... and yes, it was in <U>4th gear</U> as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_1.8T »</TD></TR><TR><TD CLASS="quote">
yup.. same with mine. it was starting to come off the dyno.. they had like 2/3 guys sitting on the trunk to help keep the car on the rollers, and that still didnt even help. good thing they stopped when they did cuz that car was seriously ready to come off
</TD></TR></TABLE>yup.. same with mine. it was starting to come off the dyno.. they had like 2/3 guys sitting on the trunk to help keep the car on the rollers, and that still didnt even help. good thing they stopped when they did cuz that car was seriously ready to come off
This isn't right. The numbers won't be all that different between 3rd and 4th. There have been a lot of posts on this if you search around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JumbosGS-R »</TD></TR><TR><TD CLASS="quote">I dyno'd in 3rd. 155whp 109tq</TD></TR></TABLE>
Thats weird...i made 157whp...but 118ft-lbs of torque.
bleeeehck....stop regurgitating all the information you read and do some research yourselves guys. for all the guys who said whatever gear is closest to 1:1, they are correct. you also cant compare different dynos to other dynos. for example, a dynojet will have a stock b16 push something like 140-145 whp and 110 torque on average in 3rd gear, whereas a mustang dyno will read something like 80 hp and 180 torque in fourth gear on the same engine. most people dont even realize this. the same goes to any awd dyno. you cant compare the results.
then according to you, you might as well dyno in 1st for maximum power
