b16 starter?
could someone tell me which year, make, and model I should use to replace my b16 starter. is it correct that I can use a DOHC V-tech del sol's starter? which others can i use?
some say all b-series starters are the same. but if you dont want to take chances get a 90-91 integra starter if you've got a 90-91 integra style clutch. and if your using 92-93 clutch, 92-93 starter.
All depends on your flywheel, not clutch...
Luckily, besides weight, all the flywheels for the b series motors is the same. SOOO any starter up to 2000 teg's should work, I'd put my money on a 90-91 teg just for the cable trans style tho.
