Comptech Swaybar End Links
Old Oct 25, 2004 | 05:33 PM
GrafxDesignGuy's Avatar
Default Comptech Swaybar End Links
I found a really good deal on a comptech swaybar/tie bar but its missing the end links, jam nuts, ect ect ... basically its just the sway bar and tie bar. Wondering where I would be able to get the necessary hardware to install it. I don't think you can use the stock parts off my car to install since to install the Type R bar you have to upgrade everything. I have a 00 LS. Here is a pic of whats included.
Old Oct 26, 2004 | 08:49 PM
stumpyf4's Avatar
Default Re: Comptech Swaybar End Links (GrafxDesignGuy)
You cna buy them of Comptech or just look at the parts list on the Comptech site and match them up yourself. Mainly they are sperical rod ends with spacers and bolts and buts. With the parts list in hand just hit up your local industrial supply store and buy some. I'd spring for the brass and stainless ones but if rust isn't a problem in your area just go with the regular ones.. just spray them with some grease once in a while.
http://www.comptechusa.com/instructions/ins078.pdf
You're gonna need some bushings and D-brackets... Energy and Prothane both have kits... spring for the ones with the grease fittings.
Old Oct 27, 2004 | 10:44 PM
dt4life's Avatar
haha eBay huh? I was lookin at the same piece
Old Oct 28, 2004 | 05:00 AM
rapid_roy's Avatar
At the least you need to get the mounting brackets from Comptech, they are custom machined pieces.
As far as the endlinks and miscellaneous nuts and bolts go, you can get those anywhere.
thumper64
Suspension & Brakes
Sep 27, 2008 04:29 PM
Finger Lickin' good
Suspension & Brakes
Jul 6, 2005 11:58 AM
nzrnk
Feb 20, 2005 07:23 PM
montyww
Sep 5, 2003 12:40 PM
ee-gsr
Jul 29, 2003 11:13 AM
