Si/Integra fuel pumps the same?
Looking for a new fuel pump and was curious if an integ model pump would bolt up and if it flows more? Its for a 91 HB. Thanks for any help.
[Modified by Cory man, 11:29 PM 12/19/2001]
You need a DOHC VTEC fuel pump, and the newer ones are all different. So I guess you need an SiR fuel pump to have one that's a drop-in. With the newer ones, you have to alter the wires so they hook up and tweak the bracket to keep the pump in place. I have a 95 GSR pump; it wasn't much work to make it fit in place. It's just a lot of work to drop the tank. But definitely worth it.
With the gsr pump did you notice any difference w/ performance. What are the exact mods to make the pump work with the wiring? Thanks man
get a Venom upgrade pump... The Newer pumps use a completely different wiring harness and size drop in pump.
The venom is a bolt in and not too badly expensive...
If I were you, unless the Si pump is going out, leave it. It's good to about 250 HP.
[Modified by SiR Kid, 11:20 AM 12/20/2001]
