91 dx hatch wont start.why?
So i just got it like a week ago.91 dx hatch COMPLETLY stock 5 spd.
It had problems starting it would take a while to start so i changed the neg batt wire and the pos wire from the batt to the fusebox and to the starter(these are the only 2 right?)becase they looked corroded. It started fine once so i though it was fixed.
Then i went out of town (not in this car) and came back and it would crank but not start so i thought it could be the battery so i jumped started it and i THINK it started and shut off after that it doesnt even crank. I got the battery checked and its charged and fine. Doesnt even crank now.
PLLEEASSEEEE
oh yea there is a signal at the starter when someone turns the key.and the fuses i checked seem good
i heard a sound and looked by the clutch and there is a relay hanging there without a cover and when i turn the key it moves.(this should happen right?) The car had a remote start alarm i think because u dont need to depress the clutch to have it start.
Any opinions.
PLLEEASSEEEEoh yea there is a signal at the starter when someone turns the key.and the fuses i checked seem good
Any opinions.
If its not turning over it could be anything from a ignition switch, to main relay, to bad grounds, blown fuse anything.
If it is turning over it could be a bad coil, rotor, cap, dizzy, alternator and so on.
It had problems starting then i changed the batt wires and i thought i fixed it.
Now it doesnt even turn over.
I checked fuses..good. And the starter gets a + signal when someone tries to start it.
I heard about the main relay problem but if this was the problem shouldnt it crank?
well check if you are getting spark: spark plugs and wires and dizzy.. then check if you are getting fuel (check for fuel pressure).... fuel pump fuel filter and fuel injector...
The only way i know how to check for spark is putting a screwdriver in the sparkplug wire and getting it close to metal and see if there is a visible spark. Right?
How could i check the disty?
How about fuel pressure/injectors or filter?
Also i tried checking my engine codes and when i turn the switch it blinks immediately 1 time as i am turning it to the position.IS something messed up(ECU)? no blinks after that at ALL...
SORRY im stupid when it comes to this?Thanks
so is there a bump for me??
I really need to get this fixed.
Any way to check the starter?
When i try and look and the led in the ecu it only blinks once AS I TURN THE KEY and nothing after that. What does this mean?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Screaming6 »</TD></TR><TR><TD CLASS="quote">
When i try and look and the led in the ecu it only blinks once AS I TURN THE KEY and nothing after that. What does this mean?</TD></TR></TABLE>
if your car is trying to turn over your starter is fine.
the ecu should blink once and not anymore. you have no ecu codes. that's good
i would try a diff. ignitor and/or coil
Look if it still won't crank at all,don't worry about all that other crap yet like fuel and spark,etc-First without it cranking it's pointless.
It is most likely the Ignition switch wiring harness.Honda's always and still having that problem.The harness is under $20 at a dealership and easy to install.
BolivianFuego
Apr 15, 2009 06:51 PM
allsho
Aug 5, 2008 04:30 PM
Rhythmsnewsn
12
May 4, 2007 11:43 PM
