Flywheel cover....
Im in the process of taking of my oil pan for a turbo drain and i cant seem to get the last couple of bolts out because of the flywheel cover. Anyone know how to remove it or get by it
Thanks
Thanks
You gots to remove it. Take off the bracket that goes from the bottom of the motor to the trans with 3 bolts in it. The rest of the bolts are obvious on the cover.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 »</TD></TR><TR><TD CLASS="quote">You gots to remove it. Take off the bracket that goes from the bottom of the motor to the trans with 3 bolts in it. The rest of the bolts are obvious on the cover.</TD></TR></TABLE>
fo sho
fo sho
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">Mine had 2 12mm bolts and 2 10mm bolts holding on the cover. </TD></TR></TABLE>
mine did to.....strange
Hatch It
Jun 7, 2005 02:08 PM
SL!M
Apr 26, 2003 09:06 PM
