h22 swap in 91 rex----already seacher and looked at 2point2s thread..answer not found.
Old Oct 25, 2004 | 03:08 PM
301am's Avatar
Default h22 swap in 91 rex----already seacher and looked at 2point2s thread..answer not found.
#1 what kinda ecu am i gonna have to convert to? will it need to be chipped?
#2do i use the old wiring from my d15 or will the h22 come will all the wiring i need?
#3what kinda extra things will i need, besides axels, shift linkage...???
#4 what year h22 engine will i need to use?
thats about all i can think of for now if i remember more qustions ill post them.
thanks.
Modified by 301am at 5:54 PM 10/26/2004
Old Oct 25, 2004 | 03:24 PM
mr_valentino20032000's Avatar
Default Re: h22 swap in 91 rex----already seacher and looked at 2point2s thread..answer not found. (301am)
hey there is another CRX with an H22 with a B series tranny check it out
Old Nov 4, 2004 | 10:16 PM
301am's Avatar
yay thanks for all the replys...
Old Nov 4, 2004 | 11:57 PM
Nerologic's Avatar
Default Re: (301am)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 301am &raquo;</TD></TR><TR><TD CLASS="quote">#1 what kinda ecu am i gonna have to convert to? will it need to be chipped?
thanks.
Modified by 301am at 5:54 PM 10/26/2004</TD></TR></TABLE>
u need to convert to OBD1 and run a p13, OR u can stay obd0 and run a chipped pr3 or pw0
depending on if u stay obd0 or obd1 u use the wiring that goes with the OBD of the ecu...u can use just about any obd0 or obd1 harness its just a matter of adding wires...
u need axles, shift cables, which ever ecu u are gonna run, the mounts all the off the h22motor and trans, a welder, a dremmel or grinder clutch master cyl and hydro clutch pedel and lines, an extended fuel line, and lots of patiance (mine took 2 months to finish, only to be totaled a few weeks later )
regarding the motor it doesnt matter, just diff yr's have diff power...
Joe Donohue
Feb 5, 2017 03:21 PM
relited
May 17, 2007 04:21 PM
iluvef8
Oct 16, 2005 02:41 AM
ekhatch18tR
Oct 26, 2004 06:31 AM
yaya
Mar 19, 2003 09:24 PM
