B16 Question - Used Search - Could Not Find
Old Oct 25, 2004 | 02:03 PM
ludedude94's Avatar
Default B16 Question - Used Search - Could Not Find
I have a 91 CRX w/ B16 swap. The SWAP was already done when I bought the car.
Can someone tell me what engine I have? The engine has this:
B16A
1028670
The Tranny:
S 1 - 1057238
What car is this B16 out of? When buying parts, what should I get parts for?
Thanks
Jesse
Old Oct 25, 2004 | 02:07 PM
EL Vap133's Avatar
Default Re: B16 Question - Used Search - Could Not Find (ludedude94)
You have a B16 engine.
Old Oct 25, 2004 | 02:09 PM
ACRProject's Avatar
Default Re: B16 Question - Used Search - Could Not Find (EL Vap133)
since your motor is a 1 million series b16a it came out of a 90 - 91 jdm da6/8 integra xsi. If it was a 5 million series it would have came out of a ef 8/9. As for buying parts it depends what you need to buy. Some parts could be used from a crx, 90-93 integra, 94 del sol vtec, and 99-00 civic si as well.
Old Oct 25, 2004 | 02:14 PM
ludedude94's Avatar
When I went to do my timing belt. I looked under 94 Del Sol VTEC and the water pump was different. I then looked under 96+ Del Sol VTEC and the water pump was the right one.
So your saying I will always have this issue about what parts could actually fit...
Old Oct 25, 2004 | 02:21 PM
ACRProject's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludedude94 &raquo;</TD></TR><TR><TD CLASS="quote">When I went to do my timing belt. I looked under 94 Del Sol VTEC and the water pump was different. I then looked under 96+ Del Sol VTEC and the water pump was the right one.
So your saying I will always have this issue about what parts could actually fit...</TD></TR></TABLE>
Yes. Most of the time i just look for parts for a 92 integra gsr. A lot of the parts off the b17 will work on the jdm b16a. But for ignition I just use a 90-91 integra cap and 91 crx si rotor.
Old Oct 25, 2004 | 02:23 PM
ludedude94's Avatar
Default Re: B16 Question - Used Search - Could Not Find (ACRProject)
Wow, so the rotor is actually off the D16? Ok, might be better off getting a newer B16 and dropping it into place
Old Oct 25, 2004 | 02:25 PM
ludedude94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ACRProject &raquo;</TD></TR><TR><TD CLASS="quote">
Yes. Most of the time i just look for parts for a 92 integra gsr. A lot of the parts off the b17 will work on the jdm b16a. But for ignition I just use a 90-91 integra cap and 91 crx si rotor.</TD></TR></TABLE>
Thanks ACR, great info...
Jesse
XYRS2LT
Feb 14, 2011 03:16 PM
racing_reject_001
12
Oct 18, 2006 10:34 AM
creatinemc
Jul 17, 2005 11:11 AM
philosofy1
Jul 14, 2005 02:35 PM
nick91civicsi
Oct 23, 2003 07:57 PM
