anyone know if this IC will fit?
get the dimensions, then go walk out to your car with the tape measure and scope it out. Prob gotta cut something, that thing looks massive.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH »</TD></TR><TR><TD CLASS="quote">get the dimensions, then go walk out to your car with the tape measure and scope it out. Prob gotta cut something, that thing looks massive.</TD></TR></TABLE>
knew someone was gunna say that. the car isnt here right now
but i was also putting the question out there to see if it does fit, how much mod. do you have to do.
dimensions-31.5" L x 10.3" H x 3.5" D
but i was also putting the question out there to see if it does fit, how much mod. do you have to do.dimensions-31.5" L x 10.3" H x 3.5" D
I've got the medium (600hp) one from Precision. it's the same size end to end, it's just taller. mine fit with modifications........ i removed the bumper support, and cut a hole in the sheet metal to the right of the radiator. my setup was completely custom, so you may route your piping differently. the first pic shows my intercooler hanging down a lot further than where i actually mounted it. where i actually mounted it- the blue connector hose on the left sits up against that silver cannister, not allowing it to go any higher. you will have to cut out the bottom of your bumper to fit the bigger intercooler cause it will hang down more (if you are using stock bumper.) hope these pics help.
i got to looking at the pic you posted of the bigger one, and i see that it wouldn't hang any lower than mine, but rather move the extra up higher. i think this wouldn't be possible without removing a lot of stuff and modifying unecessarily. i think you could turn it upside down though and it may work out.
if i were you i'd just get the medium one like i did. i doubt you are making over 600hp, but i could be wrong.
as you can see i had to cut up my front bumper a good bit to get the piping to fit. i think i went a little overboard, you can see where i cut too far on the left. you may be able to rig up a way to do it to where you can keep the black things that cover the holes, but they will be severely cut up on the inside. no....i take that back, i don't think you could keep them at all, at least mounting the ic where i did.
dude, driving without the fron bumper support will flex ur chassis like crazy, the maing reason why the support is there is for bracing. U should fabricate some kind of metal bar or something to brace it SOON!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinlude »</TD></TR><TR><TD CLASS="quote">Anthonys 700hp one fit...... sorta</TD></TR></TABLE>
lol....that thing is ****** huge
it fits....after you cut up the whole cross member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChrisRicketts »</TD></TR><TR><TD CLASS="quote">as you can see i had to cut up my front bumper a good bit to get the piping to fit. i think i went a little overboard, you can see where i cut too far on the left. you may be able to rig up a way to do it to where you can keep the black things that cover the holes, but they will be severely cut up on the inside. no....i take that back, i don't think you could keep them at all, at least mounting the ic where i did.
Haha damn. You really did cut that thing! I had to cut mine a bit too, but you really went to work on it.
To the orginal poster: I'm sure you can make it fit. Anything will fit with enough work.
</TD></TR></TABLE>Haha damn. You really did cut that thing! I had to cut mine a bit too, but you really went to work on it.
You are going to have to remove your front bumper support to fit the bigger Precision intercooler. I'm running the midsize (600hp) one and cut about 2" into the bumper support. I was thinking of running the bigger one but I still wanted to retain my bumper support so the bumper doesn't sag. I also have a 5th gen prelude.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quaalude »</TD></TR><TR><TD CLASS="quote"> I was thinking of running the bigger one but I still wanted to retain my bumper support so the bumper doesn't sag. I also have a 5th gen prelude.</TD></TR></TABLE>
that's what zip ties are for
hehe so quaalude, you didnt remove your bumper support to fit the 600? can you post some pics of your IC
and chrisricketts- can you post pics of your complete IC piping set up. in the engine bay, ect.. im trying to mock up the IC piping and just go to get it welded
hehe so quaalude, you didnt remove your bumper support to fit the 600? can you post some pics of your ICand chrisricketts- can you post pics of your complete IC piping set up. in the engine bay, ect.. im trying to mock up the IC piping and just go to get it welded
pollofrito21
Honda Fit
84
Sep 18, 2008 01:16 PM
