What can I do to get a better 60" and more traction??
Old Oct 25, 2004 | 09:15 AM
b00stedbyFastrax's Avatar
Default What can I do to get a better 60" and more traction??
ran yesterday and can only get a 1.9xx 60". hell, i am running the M&H 26x8.5x15" slicks, i should be cutting at least a 1.7 60". Best time was a 11.66 @132 mph. car is spinning from 1st to 3rd . I suspect it may be also spinning in 4th due to the fact that at the last 100ft i was at my rev limit (8800) ,could be wrong.set up is Hassports mounts and Tein RA Fr & Rear. any inpu would be welcome
Old Oct 25, 2004 | 09:32 AM
DIRep972's Avatar
Smarter than you
Default Re: What can I do to get a better 60" and more traction?? (b00stedbyFastrax)
tire pressure? launch rpm? burnout?
Old Oct 25, 2004 | 10:11 AM
b18psi's Avatar
Drag springs, LSD? I am running the same slicks with skunk2 1000 pound drag springs and an open diff. Getting 1.89 60 ft.
Old Oct 25, 2004 | 12:03 PM
camp1320.com's Avatar
L con Traction bars
H-T members get special pricing
Old Oct 25, 2004 | 12:15 PM
Default Re: What can I do to get a better 60" and more traction?? (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">tire pressure? launch rpm? burnout?</TD></TR></TABLE>
tire pressure at 6.5 psi. launch rpm at 6900. 2nd gear burnout. lots of white smoke.
Old Oct 25, 2004 | 12:17 PM
Default Re: (b18psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18psi &raquo;</TD></TR><TR><TD CLASS="quote">Drag springs, LSD? I am running the same slicks with skunk2 1000 pound drag springs and an open diff. Getting 1.89 60 ft.</TD></TR></TABLE>
tein RA coilovers. JDM Type R gearbox with LSD.
Old Oct 25, 2004 | 12:22 PM
DIRep972's Avatar
Smarter than you
maybe it was just horrible track prep, cause it doesn't really sound like ur doing anything wrong there. how much boost are u running out of the hole? and does it hook and then spin or just spin when you drop it?
the RA coilovers are 783front/559rear right?
Old Oct 25, 2004 | 12:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">maybe it was just horrible track prep, cause it doesn't really sound like ur doing anything wrong there. how much boost are u running out of the hole? and does it hook and then spin or just spin when you drop it?
the RA coilovers are 783front/559rear right?</TD></TR></TABLE>
it could very be bad track prep. dunno. running 17 psi out of the hole. it hooks for a very brief moment and then spins. not sure of the spring rates, but will check on that.
Orangeciv
Aug 15, 2008 08:46 PM
tyrone27
Oct 27, 2006 12:24 PM
93turbo16
Oct 16, 2006 04:52 PM
ISPhuevos
Sep 4, 2005 09:31 PM
TurboTegB18c
Aug 23, 2004 09:45 PM
