I need a smaller radiator...
Old Oct 25, 2004 | 08:10 AM
MooreBoost's Avatar
Default I need a smaller radiator...
I just installed a larger turbo and different mani on my DOHC ZC, and no longer have room for my fullsize radiator. I need a pretty small radiator, please suggest one, as well as which hoses I should use with it. Thanks.
Old Oct 25, 2004 | 08:12 AM
DaX's Avatar
DaX
Loved
Community Favorite
Del Sol Dual Core?
Old Oct 25, 2004 | 08:13 AM
92integra_gs's Avatar
get one from the EG CIVICs
Old Oct 25, 2004 | 08:19 AM
MooreBoost's Avatar
Default Re: (92integra_gs)
Please let me why you are suggesting this particular model, I can't tell one from the other.
Old Oct 25, 2004 | 08:20 AM
superbeastcrx's Avatar
Default Re: I need a smaller radiator... (tegunderpressure)
i dont know but i'll by your old radiator
Old Oct 25, 2004 | 08:22 AM
the EG civic has those half radiator sizes.... it will definitely make room for you turbo setup.... o btw the nonztec neon also have those half size radiators too...
Old Oct 25, 2004 | 08:26 AM
here are some links to help you out....
https://honda-tech.com/zerothread?id=1002086
https://honda-tech.com/zerothread?id=760030
say thank you!!!
also look into the 1978 civic radiator
Old Oct 25, 2004 | 08:27 AM
DaX's Avatar
DaX
Loved
Community Favorite
The Del Sol VTEC radiator is half size and Dual Core. Auto Zone has them for $100.
Old Oct 25, 2004 | 08:31 AM
MooreBoost's Avatar
Default Re: (DaX)
Im not yet sure if it will fit though.
Heres a good deal.
http://cgi.ebay.com/ebaymotors...33602
Old Oct 25, 2004 | 08:34 AM
w/ the EG civic radiator you just got to cut a small portion of the double layer part of your hood... to make the radiator go for clearance...
btw the EG RADIATOR is also dual core if you were wondering....
Old Oct 25, 2004 | 08:35 AM
MooreBoost's Avatar
You mean the "webbing" thats all over the hood? Thats all you have to do?
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (tegunderpressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">Im not yet sure if it will fit though.
Heres a good deal.
http://cgi.ebay.com/ebaymotors...33602</TD></TR></TABLE>
Uh...that is not a KOYO radiator in the picture...it's an OEM replacement. Notice the plastic end tanks. KOYO and all the performance radiators have an all aluminum construction.
Not saying this is a bad radiator...my rad on my Turbo Civic is an OEM Del Sol VTEC dual core radiator...and it has plastic end tanks.
Also...if you buy from Auto-Zone...it's lifetime warranty. Even if you smack your radiator with a hammer and put a hole in it, they'll replace it for free.
Old Oct 25, 2004 | 08:38 AM
MooreBoost's Avatar
Default Re: (DaX)
Maybe I will get an EG radiator from Autozone then.
Looks like the EG is 92-95, in which case I have read you also have to modify your crossmember.
Old Oct 25, 2004 | 08:39 AM
DaX's Avatar
DaX
Loved
Community Favorite
I'm telling you...get the Del Sol Radiator. It's the same size as the EH.
Old Oct 25, 2004 | 08:41 AM
92-95 civic... EG chassis
if they ask you which trim model just say you a 1995 CIVIC "EX"
Old Oct 25, 2004 | 08:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">You mean the "webbing" thats all over the hood? Thats all you have to do?</TD></TR></TABLE>
yea the webbing... ill get you another thread here shortly....
https://honda-tech.com/zerothread?id=806969
there you go
Old Oct 25, 2004 | 08:43 AM
HyBriDcxR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs &raquo;</TD></TR><TR><TD CLASS="quote">w/ the EG civic radiator you just got to cut a small portion of the double layer part of your hood... to make the radiator go for clearance...
btw the EG RADIATOR is also dual core if you were wondering....</TD></TR></TABLE>
You sir are wrong.
Not all "eg" not come with a dual core radiator. It's a single core piece of crap. Mine busted on me a week after i got my swap.
Get the del sol dual core radiator like the other guy already said.
Old Oct 25, 2004 | 08:46 AM
DaX's Avatar
DaX
Loved
Community Favorite
The OEM EH radiator is about 1/2" thick. The Del Sol Dual Core radiator is nearly 1" thick.
Old Oct 25, 2004 | 08:47 AM
eumoria's Avatar
Default Re: (DaX)
i have a del sol vtec rad and it didn't fit in my EF 88 hatch
it's from Koyo and it was too tall... but then again it may not be the "dual core" which may be a different model
Old Oct 25, 2004 | 08:49 AM
DaX's Avatar
DaX
Loved
Community Favorite
You will most likely have to move the mounting points and fabricate/modify/extend/move/weld/bolt the brackets.
Old Oct 25, 2004 | 08:50 AM
MooreBoost's Avatar
Default Re: (DaX)
https://honda-tech.com/zerothread?id=197168
Yeah, read that. They sound like a bitch to install.
Old Oct 25, 2004 | 08:53 AM
eumoria's Avatar
ouch, i got the rad for free and I only have a hairline in mine at the top. too much work I'll buy a new std one for $100
Old Oct 25, 2004 | 08:57 AM
yea my mistake thought that all EG came w/ it(dual core)... haahha but i got a dual core just dont got the time to install it right now....
Old Oct 25, 2004 | 09:36 AM
89dxhunchback's Avatar
Yea the 92-95 bolts right in !!! Here's all you have to do http://pg.photos.yahoo.com/ph/...hotos
Peice of cake....
