Problem*** Not getting a spark?
Old Oct 25, 2004 | 05:04 AM
KaRiZMa's Avatar
Default Problem*** Not getting a spark?
After doing the compression test on the H22A, we put the spark plugs back in the way it was and the next day tried starting the car but it wouldnt start. We pulled one of the plugs off the distributor and noticed it wasnt getting a spark. We took apart the distributor and cleaned off the fork and the little (stubby things that the fork rubs on when it turns) and still no spark. I am thinking its either the ECU or the module? Any ideas? Thank you
Old Oct 25, 2004 | 05:49 AM
hawkmgc's Avatar
Default Re: Problem*** Not getting a spark? (InnoVationZ)
Try your coil. Take a volt meter and make sure its getting power to it. Also the igniter, check those first before going and changing the ECM.
Most of the time its the coil more so if its inside the distrib.
And the little thing you talk about is the Rotor.
good luck with your whip
Old Oct 25, 2004 | 07:44 AM
Filthy Focker!'s Avatar
Default Re: Problem*** Not getting a spark? (hawkmgc)
Was it getting spark prior to the compression test???
fs
Old Oct 25, 2004 | 05:17 PM
KaRiZMa's Avatar
Default Re: Problem*** Not getting a spark? (filthy_shovel)
it was getting a spark before the compression test which is strange because we just took out the spark plugs and put them back in..
I will see if the coil has power. Thank you for the help
Old Oct 25, 2004 | 10:33 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InnoVationZ &raquo;</TD></TR><TR><TD CLASS="quote">it was getting a spark before the compression test which is strange because we just took out the spark plugs and put them back in..
You didn't disable the ignition during the test, did you? Probably toasted the coil.
Old Oct 26, 2004 | 05:49 PM
KaRiZMa's Avatar
Default Re: Problem*** Not getting a spark? (Chiovnidca)
i didnt disable it...you think the coil is screwed then? How is could that happen tho?
Old Oct 26, 2004 | 06:28 PM
SIMATIC's Avatar
check coil man,
Old Oct 27, 2004 | 05:33 AM
KaRiZMa's Avatar
Default Re: Problem*** Not getting a spark? (SIMATIC)
it probobly is the coil....do you guys know if i have to get a JDM replacement distributor or can i just buy a USDM....or do they have performance ones that go along w/my aftermarket performance crane ignition? Not sure...thats what my mechanic said.
Old Nov 1, 2004 | 04:19 AM
KaRiZMa's Avatar
Ok, i tested the possitive and negative points on the coil inside the distributor and they both how power....i guess this means the coil is junk?
xolk88
Mar 7, 2010 02:45 PM
jdm_sai
18
Feb 16, 2010 05:19 AM
Honda Hick
Feb 28, 2005 09:20 AM
smallttocs
May 25, 2004 08:39 PM
mustbenu
Jan 22, 2004 06:33 PM
