B16 swap into 90 crx
Old Oct 25, 2004 | 04:53 AM
90B16aRex's Avatar
Default B16 swap into 90 crx
Were having a problem with the wiring harness i have a 99-00 civic si ecu and the harness for that but the motor is obd1 and the distributor is and obd2 and its ******* everything up what could i do besides cutting my harness and wiring a obd1 distributor in its place?
Old Oct 25, 2004 | 06:12 AM
crxnj's Avatar
Default Re: B16 swap into 90 crx (90B16aRex)
Can u re-write ur question please so I can understand
Sounds like ur tryin to say u have an obd2 ecu with a obd1 motor..
If thats the case ,,What u should do is use ur stock wire harness and get a obdo-obd1 jumper harness and get an obd1 ecu ..
Get rid of the obd2 ecu..
TravisBiggie
May 24, 2012 07:13 AM
97DGreenEx
Oct 13, 2006 06:21 PM
i3oricua
May 24, 2003 12:20 AM
