How many miles on the tach before you change the clutch?
Old Dec 19, 2001 | 04:03 PM
Sam's Avatar
Sam
Default How many miles on the tach before you change the clutch?
I have about 40K miles now, but seems like my clutch is still working fine.
Just wonder what kind of miles do you guys get from the stock clutch.
Old Dec 19, 2001 | 05:27 PM
BoM's Avatar
BoM
Default Re: How many miles on the tach before you change the clutch? (Sam)
80k racing hard on it for 20k miles
Old Dec 19, 2001 | 05:29 PM
Dr Pooface's Avatar
Default Re: How many miles on the tach before you change the clutch? (BoM)
Totally depends on how much it is abused.
Old Dec 19, 2001 | 07:05 PM
nsxtcjr's Avatar
New User
None. The tach shows rpm, not miles.
Old Dec 19, 2001 | 07:08 PM
AssPenny's Avatar
Default Re: How many miles on the tach before you change the clutch? (nsxtcjr)
Getting ready to do mine at less then 10k Mainly going to do it bacause I smoke it bad at the strip and I'm doing an ATS final drive w/ Spoon fly/clutch combo.
Old Dec 19, 2001 | 07:11 PM
Floyd's Avatar
Well, i just picked my car up today from the getting the clutch replaced. The car has 40K miles on it and I was having some problems. The tech said he received a memo (did he mean a TSB?) about the springs in the ITR and GSR discs falling apart.
So, how does the new clutch feel? Exactly the same as the old one. All my symptoms are still there. It didn't solve anything. I'm not complaining because the work was done under warranty, but I still have to have my problem fixed.
-Floyd
Old Dec 19, 2001 | 07:16 PM
AssPenny's Avatar
Default Re: How many miles on the tach before you change the clutch? (Floyd)
Whats your problem? Did the tech that worked on your car say the spring fell out? If so, did they find the old spring?
Old Dec 19, 2001 | 07:23 PM
Black R's Avatar
25 Year Member
10k on the odo and my stock clutch is taking a ****...
What a piece of crap. I think all the stock parts can only handle the power of the stock motor. Everything appears to be a bottleneck and/ or can't handle any additonal power!
Hopefully I can get it replaced under warranty...
Old Dec 19, 2001 | 07:42 PM
nsxtcjr's Avatar
New User
Default Re: How many miles on the tach before you change the clutch? (Black R)
Sounds like a reasonable design philosophy to me... Of course, you knew that when you started making those mods, and you knew your warranty would not cover any damage caused by the mods, right?
Old Dec 19, 2001 | 07:49 PM
Black R's Avatar
25 Year Member
Oh yeah, you gotta pay to play right? Luckily my car can be returned to stock without any traces of tampering if need be...
My philosophy is to upgrade these "wear" items anyway: toda clutch and flywheel sound ok to you?
Old Dec 19, 2001 | 08:24 PM
M0NEYnH0s's Avatar
Mine jus gave out at 120k, one of the springs popped out. But ive only had the car for about 2mos. I have a friend with 150k who races regularly street and strip and his is just fine and hes been to the strip atleast 15+ times since hes had the car at 130k. But then again ive heard of people having their clutches go out with a lot less miles Just to give you a general idea.
Old Dec 19, 2001 | 08:52 PM
EG8R's Avatar
Old Dec 19, 2001 | 09:05 PM
Floyd's Avatar
Default Re: How many miles on the tach before you change the clutch? (AssPenny)
Yeah, he said one of the springs was "too much play" in one of the springs. My symptoms are vibration/noise in the pedal, the pedal not returning to rest properly, and some other issues. But my bigest problem is a rattle/rumbling that goes away when I press the clutch in. If there was a problem with a bearing on the input shaft of the tranny, could I feel it in the clutch?
Old Dec 19, 2001 | 09:33 PM
nugget8000's Avatar
New User
Floyd-did they replace the release bearing with the clutch? If they did not, that could be causing the problems you are hearing with the release bearing. When I replaced my clutch (at 101,498 miles, to satisfy the original post) I also replaced my release bearing, and the process of doing this this annoying rattling sound (very similar to the sound, but amplified ans sped up, of a worn-out release bearing when it is turned by hand) that was constant but only audiable when the car was in neutral, and went away shortly after the clutch was depressed, much to my satisfaction and relief.
My unadjusted pedal, which did not allow ANY free-play in the clutch and made it so extreme that the clutch would only work when it was partially depressed and it would not even shift if the clutch was fully depressed, then (at least I reason) wore the poor new bearing out in the two days (and about 350-450 miles) it took me to locate the problem of the clutch not working when fully depressed. Now the damn sound is back.
Just a possibility, so you might want to call the dealer to make sure they did in fact change out the release bearing at the same time. I dont think that this could be the cause of any of the other symptoms though. HTH.
Old Dec 20, 2001 | 07:17 AM
PM-Performance's Avatar
Default Re: How many miles on the tach before you change the clutch? (nugget8000)
mine took a **** before 10k
Old Dec 20, 2001 | 07:46 AM
ITR764's Avatar
Default Re: How many miles on the tach before you change the clutch? (itr206)
mine just had to have the release bearing replaced, so my tech replace the whole clutch assembly, bearings, everything!!! brand new itr clutch with 50 miles so far... mine was making a sqeaking nise until you slightly pressed the clutch pedal then it would stop. now she is as good as new and no more noises!!!! i should buy my honda tech a .
[Modified by ITR764, 11:46 AM 12/20/2001]
Old Dec 20, 2001 | 07:53 AM
Floyd's Avatar
Yeah, the invoice says the bearing was replaced, as I also thought this was the problem, but apparently not. You say that your noise was when your foot was off the pedal, and went away when you pressed the clutch, but my noise is the opposite. I was playing with it on the way to work today, and the vibration is stronger when there is a hard load on the engine. For example, when shifting from 2nd to 3rd while accelerating hard I really feel it, but if I sit at idle and press the clutch in and out I can't really feel it.
The vibration also feels stronger at the top of the pedal and goes away by the time my foot reaches the floor. If it were the release bearing, I would think the vibration would stay constant as the fork is applying pressure to the bearing the entire time. However, if a bearing was bad on the input shaft of the transmission, when the clutch is disengaged, the input shaft would slow down, and the noise would go away, and when the clutch pedal is released, the input shaft would spin up again and the noise would come back.
Am I correct on these assumptions? I really have never looked inside a tranny, but I think this is how it works...
On a normal clutch, should there be any vibration in the pedal at all?
Old Dec 20, 2001 | 07:56 AM
CPR's Avatar
CPR
Default Re: How many miles on the tach before you change the clutch? (ITR764)
Mine was replaced under warranty with a little less that 16,000 miles. I've been on the new clutch for 1,000 miles and occassionally, I have this low pitch clicking when the clutch initially engages. This usually happens when I'm engaging 1st gear. The tech that worked on my car said that the one of the springs on the clutch was broken.
Just a point to ponder---
According to Mike K, the clutch for the USDM 97-98 came from Japan and 00-01 comes from Ohio. hmmmmm....
[Modified by CPR, 11:57 AM 12/20/2001]
ITR764's Avatar
small amount, but just vibration transmitting from the motor.
esca
Feb 26, 2005 02:42 PM
2lowintegra
Jul 2, 2003 08:44 AM
White S2k
17
Apr 30, 2003 11:17 AM
PatrickGSR94
Apr 16, 2003 09:40 AM
gshockbreaker
Nov 18, 2002 04:54 AM
