Oil consumption after track day
Old Dec 19, 2001 | 03:45 PM
Sam's Avatar
Sam
Default Oil consumption after track day
Guys with track experience please help, my oil level was at the max mark on the dipstick before the track day, but after about 180 miles on the track, my oil now is at the min mark on the dip stick. That means my engine consume at 1qt? Is it normal? BTW, I am using Mobil 1 10W-30. I am pretty sure that my engine do not consume oil in daily driving. Anyone has the same experience?
Old Dec 19, 2001 | 03:47 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: Oil consumption after track day (Sam)
Adam (RS) uses at least that much in a day with his R. My car doesn't use any noticable amount, but I'm running cheaper dino oil (castrol gt-x), not more expensive synth oil
Old Dec 19, 2001 | 03:49 PM
Willard's Avatar
I use ~0.8-0.9 qts. of oil during a weekend event.
Will
Old Dec 19, 2001 | 03:50 PM
Sam's Avatar
Sam
Default Re: Oil consumption after track day (Dave-ROR)
Does Syn oil cause the oil consumption?
Old Dec 19, 2001 | 03:59 PM
bb6h22a's Avatar
Default Most of it..
..goes through your PCV, hook up a catch can and you'll be surprised how much you'll recover, not that you'd want to reuse it, but it will give you a clear indication of how much oil your "consuming". And no, the fact that your runing synthetic oil does not pre-dispose your engine to consume more oil, R engines just use oil, and they do so especially when tracked!
[Modified by bb6h22a, 10:57 AM 12/20/2001]
Old Dec 19, 2001 | 05:12 PM
SPiFF's Avatar
That kind of oil usage is normal for the B series motors. If you track your car, make sure it is full of oil. Take some extra with you and keep an eye on the oil level.
I will refill mine at least once or twice durring a 2 day track weekend.
Old Dec 19, 2001 | 05:13 PM
Big Phat R's Avatar
Mine uses a lot of oil too.
Old Dec 19, 2001 | 06:32 PM
AdamITR's Avatar
Default Re: Oil consumption after track day (Big Phat R)
Yeah, that's normal. I'm on the add gas .... add oil policy.
Old Dec 19, 2001 | 06:53 PM
BSQ's Avatar
BSQ
Default Re: Most of it.. (bb6h22a)
..goes through your PVC, hook up a catch can and you'll be surprised how much you'll recover, not that you'd want to reuse it, but it will give you a clear indication of how much oil your "consuming".
Been there (track), done that (hooked up oil catch can) and yes I was amazed at the amount of oil that was collected by the catch can. So you really are not "consuming" oil in the normal sense.
Old Dec 19, 2001 | 06:57 PM
Chris's Avatar
I used that much in a 20min session!!! 5W30 Synth
Old Dec 20, 2001 | 06:44 AM
Project X's Avatar
Default Re: Oil consumption after track day (Chris)
All you guys should consider using thicker oil when you road race, especially as much as a 15+ mins continuous session. The regular/synthetic 5W30 and 10W30 aren't good enough for the high temperature the car is going through. Consider some 10W40 or even 15W50 or your main and con-rod bearings will wear out very fast. That was one of the cause to my burnt con-rod #2 and crankshaft blade #2, spun 2 of 4 con-rod bearings, and heavily wear-out on the rest of the other bearings. I was using Mobil 1 10W30 and I thought it was safe.
Old Dec 20, 2001 | 06:57 AM
b00st-0wnz's Avatar
Default Re: Oil consumption after track day (George Knighton)
I'm going to get shot at, I know.
However, I do not use oil when I'm at the track, and I use normal, cheap oil.
All the synthetic-using ITR with which I'm familiar do use oil at the track.
Sorry, but that's my personal experience.
Mind you, I'm still thinking of switching to synthetic, since some recent dyno results seem to indicate that you can pick up a couple of horses just by switching to synthetic.
George, I agree with you 100%. EVERY SINGLE car (ITR, GSR, CRX included) that I know of that runs synth oil (all mobil 1, no other brands..) use a lot of oil a day. VoidDweller and myself run Castrol GT-X, and neither of our cars use any noticable amount.
Castrol GT-X
Old Dec 20, 2001 | 08:04 AM
Sam's Avatar
Sam
Default Re: Oil consumption after track day (Project X)
Project X,
Speaking of thick oil, should old engine use thicker oil like 10W-40?
Sam
Old Dec 20, 2001 | 08:35 AM
ZygSpeed's Avatar
Yeah, I burn oil too!
But is it necessarily a "bad thing", ... as long as you replenish it ...?
BTW -- it does in some way emperically show that there MUST be a difference between "regular" and the "synthetic"!!
Old Dec 20, 2001 | 08:46 AM
DutchITR1689's Avatar
Project X,
Sam
Honda Europe recommends 5W-40 or 10W-40 here. I don't know why all you guys use 5W-30 or 10W-30. It's too thin for high operating temperatures....
It should use some oil DURING the track days and not after the track days.
Old Dec 20, 2001 | 09:44 AM
rs's Avatar
rs
Default Re: Oil consumption after track day (EuroITR1689)
At Sebring a couple of weeks ago I used about 2 qts of Castrol GTX in about 260 miles. When I use Mobil 1 I usually use about 1 qt on the track. Then again I shift at the redline every single time and rarely let the rpms drop below 7 grand. I usually do 3, 30-40 minute sessions in the morning and the same in the afternoon. The Mobil 1 seems to hold up much better and is not as "dirty" at the end of the day. (the damn dealer changed my oil during an inspection so I ran with the cheap stuff). Sebring is a fast track and when I drive on other track I go through a lot less oil.
Old Dec 20, 2001 | 10:05 AM
b00st-0wnz's Avatar
Default Re: Oil consumption after track day (rs)
Adam: That makes sense, most cars that run synth use a LOT more dino oil if you switch back, that's why you shouldn't switch back. If you never went with Synth to begin with, I bet your car would be the same as mine, barely any oil use.
P-M-B,93EXsedan
Mar 23, 2014 05:20 AM
motegicivic
11
Jan 17, 2012 08:14 PM
LSVTEC 91 Civic
Oct 15, 2004 08:57 AM
petrv
Sep 13, 2004 04:53 AM
Petah
Aug 19, 2003 01:14 PM
