ES bushing kit come with these??
Every ES bushing kit that I have seen on ebay does not list the front or rear sway bar bushings, the motor mount bushings, or the shifter bushings. Do these come with the kit or sold separately? I was looking under my car today and notice that my front sway bar bushings are almost completely rotted and gone so i figured it might be time to replace. Also do you have to keep ES bushings lubed up all the time? How much longer would these polyurethane bushings last than OEM bushings? Also is my dx front strut bar 16, 17, 18, or 19 mm?
http://www.suspension.com, call him and he will get you all you need at a great price. Just tell him your setup. The 3 kits that you listed are not part of the "master kit"
Ryan
Ryan
The shifter and front sway bar bushings came with my kit.
You can get the motor mount, rear upper control arm, rear sway bar, compensator arm, and trailing arm bushings from http://www.suspension.com.
JMZ400
Oct 17, 2018 11:47 AM
