tires lose air
Old Oct 24, 2004 | 07:05 PM
devilpuppy's Avatar
Default tires lose air
hey, my car, whenever i goto pump gas, i always have to inflate the tires.....all my tires start to lose air, i dont know why???
somebody told me that wit the alloy rims, they are never perfect so there will always be gaps, i just have the stock rims on it, but its dropped, im not too sure if that makes an affect
Old Oct 24, 2004 | 07:18 PM
C_H_A_D's Avatar
Default Re: tires lose air (devilpuppy)
I have Factory alloys and I have to put air in mine once every three months or so. You have to do this to all four tires every time you get gas? What psi is it when its low and how high are you putting it?
Old Oct 24, 2004 | 07:40 PM
sj993's Avatar
Default Re: tires lose air (mood513doom)
Get them checked for leaks. My tires don't lose pressure for about 3 or 4 months. On stock rims as well.
'00Accordster's Avatar
how old are the tires?? tires have a life of about four years, then the rubber goes bad, even if it has 0 miles on it. they also lose about 1 PSI per month per tire
Old Oct 24, 2004 | 07:43 PM
TOP END MS's Avatar
Ya, look to see if the tire has cracks in the surface. You should keep them protected with Meguires Tire Shine (Thats what I use). Its also normal to loose tire pressure, esp. if you go over big bumps that put alot of pressure on the tires. You should only have to check them once everytime you do your oil.
Also .. if your slammed, then your camber might be wearing down the inside of your tires so bad that their leaking air.
Old Oct 24, 2004 | 07:50 PM
devilpuppy's Avatar
Default Re: (TOP END MS)
yea, i'm dropped pretty low in the front...i usually gotta fill up on teh front tires...not so much teh back
i pump them up to about 31-33 psi, and i know they gone too low when i hear my car gettin hit underneath on my driveway...thats when its at like 29psi or so
BlackLudeSi
May 16, 2008 08:45 AM
bitek
Mar 8, 2008 06:24 PM
HondaMan78155
Honda Civic (2001 - 2005)
Sep 19, 2006 06:59 PM
LoganMantits
May 20, 2005 02:52 AM
ladius
Nov 24, 2004 04:04 AM
