Damn check engine light
Old Oct 24, 2004 | 06:53 PM
99silprelude's Avatar
Default Damn check engine light
on a 99 lude, is there any way for me to check why the damn thing came on? I was just driving normal and it turned on..
Old Oct 24, 2004 | 07:55 PM
esca's Avatar
Default Re: Damn check engine light (99silprelude)
search to the max.. its been covered HELLA times..
Old Oct 25, 2004 | 05:22 AM
Default Re: Damn check engine light (esca)
ok let me rephrase.. how do i check the code?
Old Oct 25, 2004 | 05:28 AM
thelarkascend1ng's Avatar
search.
Old Oct 25, 2004 | 07:59 AM
98TypeSH's Avatar
Default Re: Damn check engine light (thelarkascend1ng)
HERE!
http://hondaprelude.to/article....html
I cant even tell you how many times ive posted this link to people asking for this. have a good time.
Old Oct 26, 2004 | 11:18 AM
PrettyLude's Avatar
if the 5th gen lude, there is a panel underneath the radio on the passenger side, take off the cover, and there lies the plug, take out the harness and use a piece of wire to connect the two prongs together and count the blinks in the speedometer
Old Oct 26, 2004 | 11:30 AM
yeegsr's Avatar
something in ur engine bay comes lose while ur car in motion....or running causing vibration to get lose....pop up ur hood...check for sensor....push in all sensor you see...
Old Oct 26, 2004 | 12:37 PM
bb6h22a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99silprelude &raquo;</TD></TR><TR><TD CLASS="quote">on a 99 lude, is there any way for me to check why the damn thing came on? I was just driving normal and it turned on..</TD></TR></TABLE>
Have you checked your gas cap? I rememeber driving along and my CEL popping on; didn't feel a loss in power, nothing abnormal. Got home, checked the gas cap and I hadn't tightened it down past 3 clicks. Quick fix? Check the gas cap, tighten it down and unhook the battery for 30 seconds to reset the CEL. If it's something else, the CEL will come back and you'll have to check the code as outlined in previous threads.
Old Oct 27, 2004 | 09:06 AM
Default Re: Damn check engine light (bb6h22a)
ok guys, thank you for your help, i suppose i didnt search hard enough, my fault, i apologize. im getting a 67 (6 long flashes and 7 short ones) and the website that 98typesh posted says that has something to do with the catalytic converter (mine is gutted), so im guessing i should just reset it. thanks again guys
Old Oct 27, 2004 | 11:26 AM
bb6h22a's Avatar
If your cat is gutted, and you're still running an OBD2 ecu, then the CEL you're getting is most likely for the 2ndary o2 sensor reading elevated CO and CO2 levels; no big deal.
Old Oct 27, 2004 | 03:57 PM
PrettyLude's Avatar
ur probably getting a cold for catalyst inefficiency and below threshold, get a o2 simulator to solve it
Old Oct 27, 2004 | 05:59 PM
thehondaguru's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">ur probably getting a cold for catalyst inefficiency and below threshold, get a o2 simulator to solve it</TD></TR></TABLE>
NguyenDC2
Apr 15, 2007 03:37 AM
egturbolsvtec
Mar 15, 2006 03:20 PM
bella_bluelude
Apr 6, 2005 10:02 PM
unKnown
Aug 25, 2004 12:33 PM
wm5holla
Mar 15, 2003 12:40 PM
