Got rid of my old manifold
Old Oct 24, 2004 | 06:49 PM
dark Sol's Avatar
Default Got rid of my old manifold
heres my old setup
and heres some pics of my new manifold
most recent
i'm happier with the log because of turbo placement
and because the under hood temps are down
Old Oct 24, 2004 | 06:55 PM
manekDC2.'s Avatar
Default Re: Got rid of my old manifold (dark Sol)
v-Band = HotSauce
Old Oct 24, 2004 | 06:59 PM
StolenTeg's Avatar
What make you decided to go with the log style, The old equal lenght look pretty good. Did you noticed the decreased in spool time since you have a log manifold now? Killer set-up
Old Oct 24, 2004 | 07:03 PM
2muchPSI's Avatar
Default Re: Got rid of my old manifold (StolenTeg)
log manifolds actually increase spool up time, just don't make as much power
Old Oct 24, 2004 | 07:04 PM
dark Sol's Avatar
the old mani would let boost creep badly so i set boost lower than i wanted and the wastegate opening killed spool up time
the wastegate only really vents off two cyl
so the log actually comes on about 700rpm sooner
but i still need a bigger wastegate
Old Oct 24, 2004 | 07:21 PM
mobceo's Avatar
looks good Cody!
Old Oct 24, 2004 | 07:54 PM
JDMs1eeper's Avatar
Nice setup. where did you get yoru Vband DP? did you order the kit w/ clamp and flanges or was it prefabbed. Looking good
Old Oct 24, 2004 | 08:17 PM
dark Sol's Avatar
Default Re: Got rid of my old manifold (JDM S1eeper)
i made it
i used a stainless doughnut to make the first part the i used 3" jbends to make the rest
i don't remember where i got the V-band flange kit
i think it came from racecar supply
the dump tube is made out of a H22 manifold (talk about making due with what i had)
Old Oct 24, 2004 | 08:35 PM
JDMs1eeper's Avatar
ok sweet, thanks.
Just wondering, because i have one also. Just seeing what others were using/doin
Old Oct 24, 2004 | 09:11 PM
Smokinsax's Avatar
The Boot
who made your origional mani?
Old Oct 24, 2004 | 10:00 PM
ISSUES-EG's Avatar
Default Re: (Smokinsax)
Old Oct 24, 2004 | 10:04 PM
project dc2's Avatar
Default Re: (Erika's_ek9)
old mani = bmc
new one ..... hrmm CRP ?
Old Oct 24, 2004 | 10:45 PM
vw_dred's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dark Sol &raquo;</TD></TR><TR><TD CLASS="quote"> the log actually comes on about 700rpm sooner</TD></TR></TABLE>
WOW! thats a pretty big difference.. What are you running on the hot side? It def. looks a lot cleaner..
Old Oct 24, 2004 | 11:12 PM
B18C1CYA's Avatar
Default Re: Got rid of my old manifold (vw_dred)
a log will spool sooner cus it works off pressure not flow like a = length
Old Oct 25, 2004 | 12:04 AM
H.A.R.T B18C1EG6's Avatar
Default Re: Got rid of my old manifold (B18C1CYA)
looks good
Old Oct 25, 2004 | 04:54 AM
dark Sol's Avatar
Polk performance made my original mani and it is good quality, but the collector had too much angle in it
and i made this manifold
this log is made out of schedule 20 ss weldells
because it was all i could get at the time
and the dropdown is made out of a piece of ss sch20 straight that i beat out
Old Oct 25, 2004 | 04:57 AM
dark Sol's Avatar
it's a pte pt63 with a.69ar on the hot side
Old Oct 25, 2004 | 05:09 AM
Thumbup's Avatar
Default Re: Got rid of my old manifold (manikgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.A.R.T B18C1EG6 &raquo;</TD></TR><TR><TD CLASS="quote">looks good</TD></TR></TABLE>
kevino002
Jan 5, 2005 08:48 PM
boosted jetta
Jul 1, 2004 09:47 AM
Full-Race Geoff
May 22, 2004 06:24 AM
project dc2
Mar 29, 2004 10:05 AM
yimmy
Jan 12, 2004 08:32 AM
