ITR OEM LOWER TIE BAR MEASUREMENTS HELP! PLEASE!
i was wonder if you guys can do me a favor, when you have time can you measure the metal piece between your lower tie bar and your subframe, the verical height of it and the horizontal width of it, im going to weld flat pieces of metal to make my own and drill a hole on it so i can bolt on a OEM lower tie bar to OEM spec instead of just welding it on. im doing this becuase i can go that route or i can use those pieces to go with my tanabe sustec rear lower brace set up where it bolts to the LCAs and the subframe...ie the part im looking to fab.
Thanks guys!
Thanks guys!
