Besides the D16A1, what H motors use a 40T cam gear(s)?
Old Dec 19, 2001 | 02:37 PM
-TJ's Avatar
-TJ
Default Besides the D16A1, what H motors use a 40T cam gear(s)?
I'm looking for an adj. cam gear mfr. who makes gears for the D16A1, which uses 40T cam and 20T crank timing gears. The ZC uses 34T/17T gears like the B series motors.
I've looked into putting 34T/17T timing gears on the D16A1, however the D16A1 has a 22mm crank snout, unlike the ZC/D16A6 which use a 24mm crank snout.
So, anyone know of any other Honda motors that use a 40T cam gear? If I can find one that is the cast spoke type (rather than the stamped steel type) I can make my own, no problem.
Thanks,
-TJ
Old Dec 19, 2001 | 09:16 PM
Gasoline Fumes's Avatar
Default Re: Besides the D16A1, what H motors use a 40T cam gear(s)? (-TJ)
I just went out and checked my spare cam gear. It's a 40 tooth cast spoke from an '85 Civic. I assume all of the EW Civic engines would be the same. There is an adjustable gear made for the '85-'87 Si that may work. I think AEM has them.
Old Dec 20, 2001 | 06:15 AM
-TJ's Avatar
-TJ
Default Re: Besides the D16A1, what H motors use a 40T cam gear(s)? (Gasoline Fumes)
I wondered about that....Some years ago I made an adj. cam gear out of one of those for my old CRX 12v motor. However, I never bothered to count teeth - I sold all my 12v stuff to a local EP class racer last year, along went the gear.
Time to go junkyarding...
Thanks,
-TJ
Catfish4748
Oct 7, 2010 10:22 AM
eg6madness
Jun 9, 2009 07:54 AM
sleeperb16a
Sep 24, 2007 08:12 AM
ky_urotrsh
Mar 14, 2007 04:04 AM
Gojira D.O.T
Feb 25, 2006 02:34 AM
