My EP
im a new member here on hondatech but ive been a member forever on ephatch....
anyway heres my car..
how i started out...
my mods
Injen RD CAI
DC Sports Ceremic Race Header
2.25 exhaust piping(with 4 leaks :mfrown: )
NextGear Intake Manifold Gasket
Aluminum Shifter Bushings
ES MM Inserts
RSX Type S Front Sway
SS Clutch Line (to be installed)
CTR Wing
CTR EK9 shift ****
CTR DIY Valve Cover
TEIN S Tech Springs
16' Rota Slips
Toyo Proxes FZ4s(shitty for track!)
Custom Plate
best 1/4 mile 15.169@92.08 w/shitty 2.376 60 ft...i can do better!!
this was with i/h/leaky exhaust/img gasket in swampy florida conditions
now with motor mounts i should getter better traction...hello 14s
Coming soon...hondata
my mods
Injen RD CAI
ES MM Inserts
CTR Wing
CTR EK9 shift ****
CTR DIY Valve Cover
TEIN S Tech Springs
16' Rota Slips
Custom Plate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alpine192 »</TD></TR><TR><TD CLASS="quote">very nice i want rims like that . very cool . you should get the angle eyse projector lights . they should drop in yours . in my 04 i had to modify the wiring harness .
you are retarded.
nice times though guy.
</TD></TR></TABLE>you are retarded.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1NasteeEp »</TD></TR><TR><TD CLASS="quote">Alpine.....
Hmmm, why do you have a Type R Badge on your car????
because it JDM
</TD></TR></TABLE>because it JDM
Hmmm. I thought you'd have an easier time of it because the '04 USDM EP3 has dual reflectors.
Our earlier cars have only one headlight bulb and one reflector. Wouldn't that actually be harder than what you did?
And how do you guys bear the fact that the USDM Si red clashes perfectrly with the JDM CTR red "H" symbols? LOL...
I couldn't bear looking at that and ended up removing both the front and rear dark red Si logos.
</TD></TR></TABLE>Hmmm. I thought you'd have an easier time of it because the '04 USDM EP3 has dual reflectors.
hey
the projector lights in my car are designed to work with the wiring system of the 02 , 03 si .
the 02 , 03 si's have a dual filiment bulb (h4) there are 2 positive's and one ground wire on your harness on each side of your car . my 04 si has lights have 2 seprate harnesses 2 postives and 2 grounds on each side . my projector lights use a h1 (high beam) and h3 bulb (low beam) . it works the same way as your h4 . the positive from each bulb is in the plug and the ground goes from one bulb to the other and then to the plug. there is the 3 wires like on your h4 . all you would have to do is just plug the plug from my light into your stock h4 harness . i have 2 separate harnees for my high and low beam , it wont work even if i tie both grounds together . you can however change it a box on the friewall i think . i have the whole wireing diagram of the the 02 , 03 and 04 car . you would have to see it in person to understand it better . i hope i explained it ok for you lol somwhat .
for the people who said i have a type-r badge . its only for looks , i gave it the euro look .i think it looks very nice . alot of people ar doing it even puting in the gauges and all . i have both front and back badges and the british flag .
in my motor trend they had a si that was modded a little and even that car had the type-r badges . it was a 02 si . they just put it there for looks .
the blacknight guy said i was retarted , id like to know what makes him put a comment like that there . i saw he lef me a nice comment in my thread about exhust , was that " you are retarted towrds me or somone else .
thanks
tom
Modified by alpine192 at 10:50 PM 10/25/2004
thanks
tom
