I have wrong ECU. Should I care much?
Old Oct 24, 2004 | 03:36 PM
genpix's Avatar
Default I have wrong ECU. Should I care much?
Hi,
I already got help on "locating" EGR valve in my '93 Civic EX.
Periodically my 'Check Engine' light goes on (when I drive faster the 45mph, and motor is already warm). And it stays on till I kill the engine. After I start again, light statys off till I reach 45-50mph. And it goes over and over.
I've read the DTC code. It's 12 - EGR valve problem.
Interesting thing is: my engine (D16Z6) does not have EGR at all.
So, previous owner installed wrong ECU. Currently, it's P07 (probably for VX). And it flags an error when it can not find EGR.
Could it cause any problems? or bad gas-milage?
I don't plan to do any racing in the near future I, simly can not do it! I drive manual transmission car for 5 days only (I started from AT, and I drove for about 10 years).
So, I don't need to do any perfomance tweaks, like chiping ECU, etc.
But I want to know what could go bad if one uses "wrong" ECU.
Please, please, tell me that everything's OK
Old Oct 24, 2004 | 03:38 PM
Eg Smurf's Avatar
Default Re: I have wrong ECU. Should I care much? (genpix)
you need a p28 man
Old Oct 24, 2004 | 03:40 PM
Archidictus's Avatar
Unceasing Measure
Default Re: I have wrong ECU. Should I care much? (Eg Smurf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by genpix &raquo;</TD></TR><TR><TD CLASS="quote">I have wrong ECU. Should I care much?</TD></TR></TABLE>
LOL.
Old Oct 24, 2004 | 03:44 PM
genpix's Avatar
I know, that P28 is a proper ECU for my car.
But I do not want to start investing in this car (I just bought it, and I did not plan to spend more that I already did).
And previous owner had smog check passed last august (I do not know how he did it with wrong ECU though).
So, I'm good till August 2006 in this department.
The question is: how bad is "wrong ECU"? I could ask Honda dealership. But I bet $100 that answer would be "you deffinetly need to buy a new ECU; you could buy it from us".
2 Archidictus:
I did expect lough (I use this topic title intentionally).
But I thought, that simple "LOL" is not the right answer for newbe. Come on, give me some sarcastic advises
Modified by genpix at 10:34 AM 10/25/2004
Old Oct 26, 2004 | 11:07 AM
genpix's Avatar
bump
Old Oct 26, 2004 | 11:30 AM
smart monkey's Avatar
civic's in cal don't use a egr, maybe the P28 you got is a P28 federal ecu and not a cal one. maybe that is why it is looking for the egr.
Old Oct 26, 2004 | 11:37 AM
StrikerX's Avatar
Default Re: I have wrong ECU. Should I care much? (smart monkey)
I bought my chipped p28 for $50. Just gotta look around and find a deal.
Old Oct 26, 2004 | 12:27 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smart monkey &raquo;</TD></TR><TR><TD CLASS="quote">civic's in cal don't use a egr, maybe the P28 you got is a P28 federal ecu and not a cal one. maybe that is why it is looking for the egr.</TD></TR></TABLE>
Yes, Civics in California do use an EGR. They are the VX and CX models.
It's looking for an EGR valve because he is using a P07 (VX) ECU.
Everything is not OK. You need a P28. NOW.
The P07 VTEC crossover is way too low, it is tuned for VTEC-E performance, it needs a 5 wire wideband o2 sensor to operate properly. The P07 is looking for sensors you don't have, and if it is switching VTEC at all, it is at way too low of an RPM.
Old Oct 26, 2004 | 04:32 PM
Default Re: I have wrong ECU. Should I care much? (Jim Truett)
what i meant was D16z6's don't use a egr. I totally did not read the part of the P07 ecu though. yes you now need a P28. sorry for not reading it through
Old Oct 28, 2004 | 05:17 PM
genpix's Avatar
Default wow!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StrikerX &raquo;</TD></TR><TR><TD CLASS="quote">I bought my chipped p28 for $50. Just gotta look around and find a deal.</TD></TR></TABLE>
we did you buy it?
could you please point me to that "around" direction?
I'd like to have it for this price
Old Oct 30, 2004 | 03:08 PM
genpix's Avatar
Default I fixed it :)
It was easier as I thought.
My P07 ECU has the same PCB as P28 ECU. There are two different PCBs for P07, I was lucky to have the one which is "correct".
So I just chipped it (I had all components; being an electronic engineer brings some bonuses: access to components and EPROM programmer).
I programmed the ROM with stock P28 program, and soldered it to my P07 box.
Took me about 30 minutes to do all this stuff.
Works great now. No Check Enging LIM anymore !!!
Old Oct 30, 2004 | 04:21 PM
Jim Truett's Avatar
Default Re: I fixed it :) (genpix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by genpix &raquo;</TD></TR><TR><TD CLASS="quote">It was easier as I thought.
Excellent.
I have yet to see a P07 with a 1720 board come across my bench.
JDMEF
Mar 3, 2011 06:47 AM
zcsport
Jul 27, 2007 09:01 PM
zCivic
Oct 23, 2004 12:00 AM
nexus da9
Apr 7, 2004 07:37 PM
seemo
Oct 12, 2001 11:21 AM
