accord 2001 radio code?
if you have an ashtray....pull it out completley so you can see the back of it........there should be a stick there with some numbers........try that.........if no sticker behind the ashtray open your glove capartment look inside of the of the glove capartment for any numbers ......if sitll you cant find it .........visit your local honda dealer ...........bad part is theyll give like 5-7 codes and you can only try 3 every hour........so good luck on guessing
go to the dealership where you bought the car. bring your insurance card (proof of registration), driver's license, and possibly even the serial code of the bottom of the deck. they'll either use the VIN or serial code to look up the anti-theft code. if the dealership gives you multiple codes like 956hondaguy said, they're stupid as hell... and not following procedure anyways. giving a bunch of codes and saying, "it's one of these, you'll have to try them all to figure out which" is the stupidest thing i've heard of...
if its not one of the three codes you can reset the ECU and give it another go
i don't deny being a smartass, but please realize this is about the most common question you'll see
