1991 accord with H22A OBDI
Old Oct 24, 2004 | 12:23 PM
Stoich EG2's Avatar
Default 1991 accord with H22A OBDI
Ok i have a 1991 accord EX and a JDM H22A. what do i need to do to make this work? is 1991 OBD0? if so what lines, sensors, etc do i need to add?
Yes I've searched and none say exactly what i should do. thanks for the help
Old Oct 24, 2004 | 12:25 PM
FatJoe's Avatar
Default Re: 1991 accord with H22A OBDI (Advan06)
you will use the same accord engine harness....you will just need to add the appropriate vtec related wiring. your car is OBD1, so you wont have a wiring headache putting it in.
EDIT: here are the wires you need to add for the swap.... taken from the basic guide
1. VTEC Solenoid: Pin A4
2. VTEC Pressure Switch: Pin D6
3. Knock Sensor: Pin D3
4. Secondary Intake Solenoid: Pin A17
Old Oct 24, 2004 | 12:28 PM
Stoich EG2's Avatar
Default Re: 1991 accord with H22A OBDI (FatJoe)
WOOH! thank you sir
Old Oct 24, 2004 | 12:31 PM
FatJoe's Avatar
no prob
georgen316
Mar 11, 2013 04:53 PM
ricb20vtec22
Oct 15, 2012 06:53 AM
darrinirox
Jun 8, 2011 11:23 AM
phatcardesignz
Dec 10, 2008 02:35 PM
92accordh22a
Dec 8, 2006 11:34 AM
