Nice as hell out today, 2.0L GSR pics..*56k grab a brew*...
Dayum its nice as hell out, finally we are starting to see a drop in temp down here in FL...breeze is blowing and everything...snapped some pics of the new DC2(fully built 2.0L) and what not..check um out..
edit*no more ghey azz pix0r
Modified by lanojp1 at 4:23 PM 10/24/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverEH2 »</TD></TR><TR><TD CLASS="quote">haha clean car man...you have something against lowering springs/coilovers?</TD></TR></TABLE>
yea i do its called all GO no show...haha no its basically priorities..im trying to get my turbo setup on their ASAP so no money for suspension...
the setup is...
Fully built and GE Sleeved 2.0L Block
84.5mm Endyn Rollerwave Pistons (9.2:1 compression)
Eagle H-beam Rods
ARP Rod Bolts
Polished and balanced crank
Cometic Headgasket
Endyn custom Oil Pump
ARP Headstuds
Endyn Oil Catchcan system
ITR outer valvesprings
Portflow Inner Valvesprings
Portflow Retainers
2001 CTR Cams
Skunk2 Cam Gears
Endyn Custom Flat valves with Black Nitride Coating
JG Intake manifold
AEM Short RAM Intake with K&N Filter
Skunk2 Intake Manifold Gasket
JDM DC Header (2.5")
Custom test pipe
APEXi 2.5" catback exhaust
Walboro 255lph Fuel pump
SS braided lines from fuel filter to AEM fuel rail
Aeromotive FPR 1:1
ACT 12lb flywheel
Clutchmasters stage 3 with sprung hub
Quaife LSD
Energy suspension shifter bushing
the setup is...
Eagle H-beam Rods
ARP Rod Bolts
Cometic Headgasket
ARP Headstuds
Portflow Retainers
2001 CTR Cams
Skunk2 Cam Gears
JG Intake manifold
Custom test pipe
Aeromotive FPR 1:1
ACT 12lb flywheel
Quaife LSD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99 EK »</TD></TR><TR><TD CLASS="quote">Nice car.....but is that the stock ride height, or did you put a lift on it.
thats a lift kit booyyy...4x4 off road sleeper..
</TD></TR></TABLE>thats a lift kit booyyy...4x4 off road sleeper..
very cool car, never would think a motor like that in a car like that, get some ls wheels
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r_Senik »</TD></TR><TR><TD CLASS="quote">u need to lower it bad. but you got a nice sleeper.</TD></TR></TABLE>
yes i know this...D2 coilovers coming after boost..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_cruz »</TD></TR><TR><TD CLASS="quote">nice sleeper.
muhahahahahahah.... hopefully no one sends this picture to a ghey site.
too late
too late
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpugenEG »</TD></TR><TR><TD CLASS="quote">You must work out....lol
HAHA, what makes you say that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrashin »</TD></TR><TR><TD CLASS="quote">too late</TD></TR></TABLE>
Jokes on you...you knew where to send them.
