Exhaust size help...
Old Oct 24, 2004 | 09:17 AM
Dropped90Integra's Avatar
Default Exhaust size help...
Ok, I'm buying a 94 Civic DX Coupe on Monday. I'm looking to start upgrading stuff slowly but surely just need opinions because don't know civics too well, had a turbo DSM before. First is exhaust, I'm gonna put a B18C1 GSR motor in it down the road so what exhaust size is good for my 1.5 now and than the 1.8 later? I was thinkin about 2.5 cat-back, test pipe, and than I'm stuck on headers, should i get 4-2-1 or 4-1? Intake wise I'm gonna do a cold-air with the AEM by-pass valve but what size intake pipe is good? Bascially thats all I'm doing motor wise until I get the GSR motor, I'll be working on the exterior and interior stuff until than. Thanks for any help
Old Oct 24, 2004 | 09:19 AM
eclypzex's Avatar
Default Re: Exhaust size help... (IntegraB18LS)
well i just swapped my gsr into my ek hatch a couple wks ago and im going with a cai, dc jdm 4-1 headers, 2.5 exhaust w/ es oval exhaust. hope this helps.
-albert
Old Oct 24, 2004 | 09:35 AM
McNizzle's Avatar
Default Re: Exhaust size help... (eclypzex)
imo id just go with 2.25" exhaust
Old Oct 24, 2004 | 09:38 AM
Yea, I'm deciding between the 2.25 or 2.5, I guess the 2.25 should be fine on the GSR motor right? Which header is good, which one does what for torque?
Old Oct 24, 2004 | 07:43 PM
Bump.... anyone else have any ideas?
Old Oct 24, 2004 | 07:49 PM
Knightmare69's Avatar
My friend with a H22 and Injen CAI runs a 2.25 piping with universal cat, cherrybomb resonator and Apex-i N1 Muffler. This was downgraded from a 2.5 piping, no resonator and cheap fart can and you can def. tell a better difference after the change. There is alot more grunt on the low end and with the N1, he still has room for the high end pace. I would suggest running 2.25. All the honda's I work on run 2.25 unless it's a built NA motor or FI one.
Old Oct 24, 2004 | 07:53 PM
Aight than, I'll probably go with the 2.25 in that case, future upgrade is gonna be a built GSR motor or 2.25 should be cool. Any idea on intake pipe size, or just get an AEM cold air for it. By the way before I buy the car tomorrow, is there room for improvement on the DX's, as in putting the GSR motor in and what not?
Old Oct 24, 2004 | 08:20 PM
eg6infinite's Avatar
i suggest you not waste money in a header for the sohc if you're planning to swap into a dohc later. they aren't interchangeable.
air intake, cat-back exhaust system, and fpr are some things you can use later in your dohc engine, so you can upgrade those while having your sohc.
Old Oct 24, 2004 | 08:28 PM
Didn't even think of them being interchangable, well I'll wait on that but should I get 4-2-1 or 4-1 when the DOHC goes in? whats the difference between the 2?
Old Oct 24, 2004 | 08:56 PM
4-2-1 improves mostly midrange power.
4-1 improves mostly top end power.
I recommend a 4-1 for a gsr, more top end for vtec because most likely you'll want to be in vtec while you're racing.
Old Oct 25, 2004 | 12:24 AM
Jedi_Sol's Avatar
what are your HP goals for the GSR motor?
Dorkenheimer
14
Jul 19, 2015 11:12 PM
helldriver88
Oct 9, 2010 04:33 PM
Badger401
Jul 30, 2004 01:28 PM
Norcalstoppy
Sep 17, 2003 06:49 AM
es four
Apr 2, 2003 02:23 PM
