wierd noise in ek
Old Oct 23, 2004 | 11:13 PM
xoutlawz00x's Avatar
Default wierd noise in ek
i got a weird noise in my 97 dx civic stock engine..whenever i put in in first and it revs high i start hearing this clinging noise also in second gear.. i don't sound like its coming from my exhuast.. the car was runnin LOW on oil for a while cause i forgot to check the level cuase my car burn oil like crazy but doesn't smoke or have a oil leak i don't know if the problem can be linked to that.. tranny bucks when starting first gear.
thanks
Old Oct 23, 2004 | 11:19 PM
SOHC4life 96's Avatar
Default Re: wierd noise in ek (xoutlawz00x)
I think you have a spun rod bearing. But don't take my word, I'm not a mechanic. For your sake, I hope you don't.
Old Oct 24, 2004 | 07:50 AM
Default Re: wierd noise in ek (DOHC4life)
how is that usally done what did i do wrong
Old Oct 24, 2004 | 07:43 PM
is that in my tranny
Old Oct 24, 2004 | 08:23 PM
i guess its in the block..
also i know i was low on oiil and my cluster didn't indicate that does any one know what can be wrong. it has no leak or smoke coming out the back but burn oil fast.. thanks and how much would it be to replace a spun rod bearing
Old Oct 24, 2004 | 08:26 PM
Yes it is in your block. It is cause by very low oil and the bearings not being lubricated enough. And unfortunatley, they are a bitch to fix. I don't know a lot about it (hope I never have to learn the hard way), but there are people on here that do and will help you more than I can. As for the oil light. Those are "idiot lights", they only come on during EXTEME conditions, as with oil, it will come one where there is almost no oil left. Stupid design if you ask me. Good luck man.
Old Oct 24, 2004 | 08:35 PM
Luserkid's Avatar
Ouch dude.... clunking sounds arent good. Where are you located?
First off stop driving, dont even take the car around the block, because the block might go and just leave you there.
Driving with no oil is very bad because it could easily break damn near anything in the block. That clunking sound could be a spun rod, do you hear it in any other gears (im more then sure you do). Labor is going to cost you on rod bearings, its better to do it yourself if you know how. If not you might have to bite the bullet, provided its a spun rod.
It might be a bent/warped rod do to being to hot and just didnt break yet, which is even worse then a spun rod because youll have to rebuild the block. Sorry to say but you just about fucked yourself over without running a oil pressure gauge. Oil is very important to cool down your motor, without it you have nothing. You shouldnt run anywhere under 20psi on idle and 80psi WOT.
I had a friends tercel that was ran with no oil, that **** blew up (literally). I spent more then 1/2 of my senior year working on it just so it could happen again. I was beyond pissed. PLEASE PUT OIL IN YOUR CAR!!!!!! (that goes to everyone)
Old Oct 25, 2004 | 11:12 AM
Default Re: wierd noise in ek (Luserkid)
im located in connecticut.. and i only hear it 1st and second gear. 1st louder than second.. ive been driving it for almost a week now.. now that i put oil in it sometimes i hear it sometimes i don't but i hear it most of the time.. i have a freind taht can fix it or atleast take a look at it for me..
after all its a stock pos motor im see if i can find the block for like 200 bucks.
thanks
Old Oct 25, 2004 | 11:17 AM
Luserkid's Avatar
Check your valves, do a valve adjustment and see how they look.
Old Oct 25, 2004 | 11:36 AM
mat's Avatar
mat
you sure it's not the tranny i hear a something in 1st and 2nd i think it's the ISB.
Old Oct 25, 2004 | 01:30 PM
Default Re: (mat)
i took it to two mechanics and they said it was most likely the tranny.. and i forgot to mention when im not in gear and i rev up the engine i don't hear it. its only when the car is in gear and only in 1st and 2nd.. im going to put some lucos tranny fix and drain and refill the liquid..
Old Oct 29, 2004 | 08:38 AM
Default Re: (xoutlawz00x)
sound go worst but im sure its the tranny
Kahl23
Honda Civic (2006 - 2015)
May 16, 2012 08:57 AM
092eg6
14
Mar 28, 2010 09:18 AM
the_dxB16
14
Jan 1, 2009 08:57 AM
Rah Rah
Dec 30, 2003 06:24 PM
tha Big EZ
Jul 17, 2003 08:40 PM
