recommended build for 90 Si?
Old Oct 23, 2004 | 08:23 PM
paul71's Avatar
Default recommended build for 90 Si?
Anyone got ideas for a d16a6 build that is streetable for my 90 Si?
Cam? I'm in the middle of trying to work out a glitch with a colt cam regrind. Not having much luck?
I've got a p&p b7 head for it. Just wondering what I could do with the shortblock? Pistons (88-89 Acura? p27?)
Thanks
Old Oct 23, 2004 | 08:32 PM
N1ghtM0nkey's Avatar
Default Re: recommended build for 90 Si? (paul71)
If you just want a little bit more streetable power you would probably get more bang for your buck and a lot less headaches if you focused on the top end rather than the bottom end.
You might consider having a little bit milled off the head to increase compression.
Old Oct 23, 2004 | 09:44 PM
CRX_1.8T's Avatar
https://honda-tech.com/zerothread?id=878010
there is a small thing on the D series here, as well as the others that you may want to consider as an alternative. try searching also.
Old Oct 23, 2004 | 10:04 PM
paul71's Avatar
Default Re: recommended build for 90 Si? (CRX_1.8T)
nice writeup. thanks
Old Oct 23, 2004 | 10:09 PM
dr_latino999's Avatar
If you can't find what you want here in the D-Series info -- since this is a B-lovers land -- you can always go to http://www.d-series.org, they will be plenty helpful
whyS0serious
15
Nov 9, 2009 01:27 PM
paul71
Oct 11, 2004 12:11 PM
RaceProfessor
Apr 12, 2004 01:13 PM
4g_hatch
Aug 28, 2003 05:42 AM
