Problem after Disk swap....
Old Oct 23, 2004 | 07:01 PM
igone916's Avatar
Default Problem after Disk swap....
I finally got my rear disk swap on my ek hatch....before the swap, i only had 95 GSR fronts....The braking was great...after i finished the 00 si rear brakes on the car the braking does not seem as aggressive as it was with the drums...when i brake it feels really soft and I can still push the brake pedal further....is this normal?...I bled the brakes...Can someone tell me why its doing this...any help would do...
Old Oct 23, 2004 | 08:17 PM
gotboostedvr6's Avatar
Default Re: Problem after Disk swap.... (igone916)
id try to use the proper master cylinder 15/16 or at least 7/8 and bleed again
Old Oct 23, 2004 | 08:19 PM
pdiggitydogg's Avatar
Disc brakes are use more fluid than drum brakes to stop.
Im surpirsed your pedal didnt sink more w/ the front integra brakes.
You can rebleed if you want, but you should probably upgrade your master cylinder and booster to a larger one; either 15/16ths or 1" integra)
Old Oct 23, 2004 | 08:20 PM
PH3593A's Avatar
did you replace your proportioning valve?
Old Oct 23, 2004 | 08:22 PM
thats not necessary
ek hatches and the em1 si have the same prop valve
Old Oct 23, 2004 | 08:23 PM
mrnice1058's Avatar
i put rear disk on my lx and i had the same problem the braking didn't seem right but i changed the master cylinder and booster to a 99 integra and it was a lot better you should do the same thing then it might help
Old Oct 23, 2004 | 08:53 PM
TOP END MS's Avatar
I stumbled uppon an adjustable proportioning valve the other day. Can't remember who made it.. Earls maybe?
Old Oct 24, 2004 | 12:14 PM
igone916's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Disc brakes are use more fluid than drum brakes to stop.
You can rebleed if you want, but you should probably upgrade your master cylinder and booster to a larger one; either 15/16ths or 1" integra)</TD></TR></TABLE>
With the GSR fronts, the brakes worked really well...if i change the master cylinder, will the Gsr fit the ek hatch...
Old Oct 24, 2004 | 12:16 PM
A.E Motoring's Avatar
Default Re: (igone916)
i have the same problem..i just did my swap last night...on my dx coupe...pedal almost goes down to the floor before it starts braking
Old Oct 24, 2004 | 01:40 PM
depending on whether its a jdm peice or not you will have to bend the lines.
If its an abs unit, you will need to reflare (good chance of it anyway)
I have a how-to at the thread at the top of the civic page. Its very easy.
You cannot just put the mc on, you need both mc and booster.
edit****
and theyre not "gsr brakes"...theyre integra brakes (theyre all the same)
Old Oct 24, 2004 | 05:46 PM
igone916's Avatar
Default Re: (JDM BoI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM BoI &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem..i just did my swap last night...on my dx coupe...pedal almost goes down to the floor before it starts braking</TD></TR></TABLE>
Right now its working pretty well....I didn't change anything, jus kept bleeding the brakes a few times....I drove it, then came back to bleed it again...did that bout 3-4 times and its working fine now...thanks for ur input...
classic69
28
Jan 8, 2025 08:12 AM
whole9
10
Mar 30, 2007 10:00 PM
xoutlawz00x
Apr 3, 2005 06:07 PM
roc
Nov 30, 2003 06:54 AM
91civ
11
Jun 26, 2002 06:30 PM
