DH-Racing 74mm billet throttle body...NICE!
hey guys this is back up do to a flaked out buyer. DH racing 74mm billet throttle body in new perfect condition. these retail for over $350 new id like to get $225 shipped.I bought this for a GSR but i believe it will fit most D,B,and H intake manifolds.many references from H-T more pics if needed
[IMG][/IMG]
[IMG][/IMG]
u taking ne trades here is what i am offering https://honda-tech.com/zerothread?id=1036952
Good luck with the DH Racing throttle body. I've seen a couple of those throttle plates stick badly.
There was this guy in MN that bought one of them and had nothing but trouble with the inferior MAP sensor port design and sticking throttle plate.
He says Dave Hickman told him just to spray it with WD40. All that did was goo things up and attract dust and grime.
He has since used OEM Type R and everything has been fine.
Just so you know, if you are using it on a Type R intake manifold, you need to enlarge the about 2mm. On B16, etc, other manifolds you will have to more.
It may say 74mm but by the time it narrows down to the actual throttle plate opening, its only 2mm over stock Type R size.
Its pretty, I give it that. Ive seen other designs similar to the DH Racing throttle bodies. I believe its made by RPM. There a few other names on those as well. I saw one didnt have issues with the MAP sensor. I think DH Racing had a batch of older, "problemed" throttle bodies.
Just passing along what Ive seen and heard. GOOD LUCK!
typeR#0427
Southwest (Sales)
Feb 27, 2010 08:32 AM
