Is it possible to buy mounts for automatic civic to make it automatic to manual?
Old Oct 23, 2004 | 04:37 PM
SpAnIsHBoost's Avatar
Default Is it possible to buy mounts for automatic civic to make it automatic to manual?
Hey guys, need ur help on this one. I got a 1994 honda civic ex, its automatic, but in immacculate condition at 94k. What i wanted to do originally is put an ls motor with a gsr head, and make it manual. But the tranny that goes ''with'' i think gsr tranny Y 80 doesnt fit the tranny mounts on my car. So i cant do this project. So now i just want to convert my civic from automatic to manual but i cant find the tranmission mounts. So is this possible to do with my civic or what?
Old Oct 23, 2004 | 05:44 PM
jhota's Avatar
Default Re: Is it possible to buy mounts for automatic civic to make it automatic to manual? (SpAnIsHBoost)
1. wrong forum.
2. your civic has a d series engine. the ls is a b series engine. you need a mount kit to swap in the different engine type. try the hybrid forum for more help.
Old Oct 23, 2004 | 10:09 PM
drussell4801's Avatar
Default Re: Is it possible to buy mounts for automatic civic to make it automatic to manual? (jhota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhota &raquo;</TD></TR><TR><TD CLASS="quote">1. wrong forum.
2. your civic has a d series engine. the ls is a b series engine. you need a mount kit to swap in the different engine type. try the hybrid forum for more help.</TD></TR></TABLE>
1: correct
2: INCORRECT. <U>To put an OBD1 b series motor in a 92-95 civic engine bay, all you need are the stock b series motor mounts that were on the motor you're swapping in. You do not need a mount kit like you do with the older 88-91 civic/crx stuff.</U> But if you're trying to put an OBD0 LS motor in your OBD1 car(which wouldn't make sense with a GSR head, btw), then I'm not sure.
Also, doing a automatic to manual swap is more complicated than just the mount. You have to install a clutch pedal, shift linkage, shifter, and you have to rewire some pins I believe. Not a good idea for a first project.
good luck, and if you want a fast car that is still automatic, buy an H22 from me.
Old Oct 23, 2004 | 10:16 PM
dr_latino999's Avatar
Default Re: Is it possible to buy mounts for automatic civic to make it automatic to manual? (drussell4801)
And since this is a newer car he would have to deal with the addition of Hydraulic clutch lines.
Old Oct 23, 2004 | 10:56 PM
Default Re: Is it possible to buy mounts for automatic civic to make it automatic to manual? (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">And since this is a newer car he would have to deal with the addition of Hydraulic clutch lines.</TD></TR></TABLE>
oh yeah, the lines and the slave/master cylinders
good catch.
Old Oct 24, 2004 | 04:38 AM
jhota's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drussell4801 &raquo;</TD></TR><TR><TD CLASS="quote">2: INCORRECT. <U>To put an OBD1 b series motor in a 92-95 civic engine bay, all you need are the stock b series motor mounts that were on the motor you're swapping in. You do not need a mount kit like you do with the older 88-91 civic/crx stuff.</U> But if you're trying to put an OBD0 LS motor in your OBD1 car(which wouldn't make sense with a GSR head, btw), then I'm not sure.</TD></TR></TABLE>
really? that's cool!
but why do they make mount kits for those cars if you don't need them? is it just a performance thing?
Old Oct 24, 2004 | 05:10 AM
Yup, just a performance thing, that way the mounts you put in are stiffer
Old Oct 24, 2004 | 05:16 AM
92integra_gs's Avatar
you will need to do fabrication when converting auto to manual... and some welding...
Old Oct 24, 2004 | 08:34 AM
Default Re: (92integra_gs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs &raquo;</TD></TR><TR><TD CLASS="quote">you will need to do fabrication when converting auto to manual... and some welding... </TD></TR></TABLE>
I've always wondered about this.
Nothing works except welding?
what is necessary when changing over to manual from auto if you're putting in an h series? ( as far as mounts, i know the other stuff)
btw, thanks for the good Info!
Old Oct 24, 2004 | 06:26 PM
Default Re: (drussell4801)
bump cause i'd like to know this..
Civ-dx-96
Apr 5, 2013 02:50 AM
Danronian
Apr 18, 2006 05:37 PM
CR-V-tech
Mar 31, 2004 07:52 PM
whiteboythatcuts
Apr 1, 2003 05:38 PM
98civicLXRyder
Sep 16, 2002 03:20 PM
