98 Front End Fitment
Old Oct 23, 2004 | 03:30 PM
boosted96ls's Avatar
Default 98 Front End Fitment
I recently bought a 98conversion, i tried putting on my 96 ls and it wouldnt fit correctly. The bumper and fenders wouldnt line up evenly. I may be missing some parts when i sold my old front end but im not sure whats missing. anyone have a picture or diagram.
Old Oct 23, 2004 | 03:56 PM
KaMeKaZi's Avatar
Default Re: 98 Front End Fitment (boosted96ls)
did u remove the bumper support? should be like a foam support that u should remove. then it should fit perfect.
Old Oct 23, 2004 | 04:03 PM
JBBNJ609's Avatar
Default Re: 98 Front End Fitment (Turbo95LS)
you dont have to remove the foam, or atleast i didnt . . .
do you have the right lights ??? unblot the lights or loosen them atleast and move them with the bumper to get it to fit right, then after the bumper is on and bolted in, fix the lights so they look/fit well and tighten everythign back up . . .
Old Oct 23, 2004 | 04:05 PM
Default Re: 98 Front End Fitment (jason bouchard)
i removed the foam. yeah it the right light..but somehow it wouldnt fit correctly. everything fits, but its not lined up right. i think im missing some screws or brackets..
Old Oct 23, 2004 | 04:07 PM
KaMeKaZi's Avatar
do u have 98-01 head lights or is it from your 96?
Old Oct 23, 2004 | 04:12 PM
i have the 98+ headlight. like i said, everything fits. but its somehow not lined up correctly..i've spent over 2 hrs trying to figure out what the problem is..and still dont know..everything is fine, bumper no dents, etc
Old Oct 23, 2004 | 04:19 PM
DOHC-ter AMIEL's Avatar
is your car slammed? my friend had the problem everything is right but it didnt line up right. later on we found out that his chassis is a little bent cause his car was slammed and all those years of going up and down driveways caused him some chassis flex
Old Oct 23, 2004 | 04:23 PM
Default Re: 98 Front End Fitment (AMIEL)
yeah man its pretty low..but im not sure if that has to do with it..at least i dont so..
does anyone have a pic of the front end from helms manual?
Old Oct 23, 2004 | 04:30 PM
shamoo's Avatar
Will you make something up for me please?
Sometimes, it's just bad luck and it won't fit "perfectly" because of slight body flex over time. I have seen this many times.
In any case, do you have the little piece of "weather stripping" between the bumper and the fender? And also the stripping between the hood and the bumper? Did you make sure all the bolts are in? There are several under the fender area (you have to get your head in there to see all of them). Some of the bolts/screws there will "pull" the bumper toward the bumper pretty well. Make sure you check them all.
Good luck and let us know.
Old Oct 23, 2004 | 04:34 PM
Default Re: 98 Front End Fitment (shamoo)
yeah i probably just missed some screws..i need to go double check. i hope thats the case..
Old Oct 23, 2004 | 04:38 PM
KaMeKaZi's Avatar
good luck man. hope u get it to fit.
Old Oct 23, 2004 | 04:46 PM
- LoL - db8's Avatar
mine fit perfectly. did you get a oem bumper?
Old Oct 23, 2004 | 04:51 PM
Default Re: 98 Front End Fitment (screwjdm)
yeah its an oem bumper, none of the pieces are wrong, all oem, no dents, cracks, etc
Old Oct 23, 2004 | 04:53 PM
ben_eg6's Avatar
all you need to conver your 96 to 98 is 98+ front bumper, 98+headlights, and 98+ corner lights everything else use your old stock. it should fit perfect , if not then some thing wrong with your 96 teg front body. who took out your old bumper and head lights?
Old Oct 23, 2004 | 04:59 PM
Default Re: 98 Front End Fitment (SIGNALAUTOLSR)
i took out the old ones myself. there is a gap between the bumper and fender. i tried pulling it close but the closest i got was about an one inch gap between the fenders and bumper..
Old Oct 23, 2004 | 05:04 PM
Rory Breaker's Avatar
It depends on a lot of things...one being the order of how you tighten the bolts when the bumper is on (as mentioned above with the headlights) and also if you have all of the clips necessary. If you dont have the end clips for example, it wont line up with the bumper right. If you tighten the top bolts before the end clips, then it will naturally pull the bumper forward, making it harder to snap in to the fender and not lining up.
All in the install.
Old Oct 23, 2004 | 05:21 PM
Default Re: 98 Front End Fitment (newgsrdriver)
yeah i just checked, im missing a few screws..its under the fender and some other places. where can i buy these screws? can i just have a shop order new screws/bolts/etc and install it for me?
Old Oct 23, 2004 | 05:22 PM
ben_eg6's Avatar
where are your old screws? how did your old bumper fit ? any gaps between the fenders and the bumper before? if not then you must forgot some bolts or screws. Its supper easy to conver 96 to 98.
Old Oct 23, 2004 | 05:27 PM
there werent any gaps before. i couldnt find any screws, and dont remember which one is for which. I believe i lost some during the process of selling my 96 front end
bombjester
Sep 18, 2009 11:32 AM
teggylover
Feb 8, 2009 09:20 PM
skata89
Oct 23, 2005 01:26 PM
allmotor.net
Mar 6, 2003 11:29 PM
jteasy
Jun 22, 2001 06:37 PM
